Outlaw 970
VR3
VR3 Posts: 29,437
edited April 2007 in Electronics
http://www.outlawaudio.com/products/970.html
Any thoughts? Just looking for a good Pre with updated features.
I see it doesnt have HMDI or w/e - is this important? Im not big on TV and will eventually run a better TV than I currently have.
Post edited by VR3 on
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    From what I have read, the 970 is a pretty big step down from the 990. I would get something inexpensive (used of course) until the HDMI pre's start coming out later this year.
    (in my case - I will have to wait a few years just cuz I can't afford what I want new....)
    Michael
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Who uses DVI?? HDMI not as important as audio inputs.
    How many HDMI's do you have?
    3 component video inputs = OK 3 optical inputs = bad.
    First, figure what Audio and video inputs you need.
    1.3 HDMI not out yet thats why I say at this point HDMI not important.
    engtaz
    engtaz
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    I have the Outlaw Audio 990 pre amp.. it's my first real home theater pre amp.. it's quite good IMHO. For me not having HDMI was a no issue. I run everything with component video anyways.. component video looks exactly the same high quality as a digital connection.. ie: DVI / HDMI. very few people can see a difference between component and HDMI.
    Go for the 990 pre if you can. It's a good bang for the buck. Outlaw audio has excellent customer service as well.
    PolkFest 2012, who's going>?
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    What is the difference in SQ between the 990, and 970? I have been looking at these too. The only thing that turns me on about the 990 is phono inputs.
    Thanks Ben
    Ben
  • danger boy
    edited April 2007
    check out the 970/990 compairson chart
    http://www.outlawaudio.com/products/comparison.html
  • ben62670
    edited April 2007
    Thanks for the link DB, but I have already been there. I have checked out all the features, and the only thing it boils down to for me is SQ.
    Ben
    Ben
  • danger boy
    edited April 2007
    I've never owned the 970 pre, so i can't say how it sounds compaired to the 990. I was very suprised just how good 2 channel sounds from a HT pre amp with it though. I had my doubts that a HT pre amp could do 2 ch too, but it can, and does it well.
  • ben62670
    edited April 2007
    Thanks DB thats what i am mainly looking for:)
    The one thing I really like about the 990 is the XLR outputs on the 990.
    Can you use rca, and XLR at the same time?
    Sorry about the HiJack
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2007
    From what I have read, no you can't.
  • danger boy
    edited April 2007
    I would think not... and for short runs of cable length the extra cost of running XLR cables isn't worth it. stick with the RCA's.
  • Gaara
    Gaara Posts: 2,415
    edited April 2007
    I thought HDMI was the new way to transfer audio, as even if you don't have 1.3 you can still transfer PCM via the older standards. The only other way to get the multi channel PCM would be running 6 or 8 cables form the player to the pre.
    This is all of course assuming you are using a newer Blu-Ray or HD-DVD source. To my knowledge if you aren't going to use HDMI for video there is no real benefit for standard DVD players.
    Jared
