RT1000i single speaker as center...
francis1967
I hope I made a decent choice here?
RT1000i brand new cherry single speaker
I was thinking the RT1000i would make a good center channel speaker with solid depth and muscle. Am I not too far off with my assumption? I can pick it up for free and it is brand new...$86 was my winning bid. I never thought it would go so low, but now I own it :rolleyes:
It will replace a CS400i which I now can put on the market and have $125+ leftover after paying for the RT. Hope I made a good choice...
Post edited by francis1967 on
A 40 inch tall center speaker? You currently use 2 400i centers? I guess I don't understand your setup goals. The 1000i is about half the speaker the 400 is BTW.
Did you think the 1000i was a CS1000P?HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
It was a great deal for a new speaker for parts or try and find a match,.. However i never understood why people want to use towers as center speakers.. I think the 400i's you have are a way better choice.. and i wouldn't sell them.. are you going to lay the 1000i on its side? and 2 400's are more speaker then 1 rt1000iMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Well, you both certainly gave the whole idea some thought. I wasn't really going to put it on its side. I was going to put it right in the middle between the mains. I have a picture on a screen that is high enough to fit the 1000i under and in the middle.
Faster100...you are probably right...I should just hang on to it and check stores and used markets for a matching 1000i and then go from there.
In the meantime, as a fix on my weirdness, I guess I could use the 400i's as L/R mains. I can tone the bass down on the 1000i and match it to the output of the 400i's.
I appreciate both your thoughts. Sitting here before my computer screen - in a new situation with no wife to give me grief over my big black boxes all over the house - ....well, it's hard not to want to buy every cool deal on Polks and use them somehow. You should know, this isn't even close to the craziest Polk purchase lately. I have picked up like 7-8 odd polks lately trying to put them to use all over the house. I just put two small Monitor 4s as computer speakers with a 30 yr old HK integrated I found on a flea market locally for $5 and the speaks were also $5. I didn't need them, but I just couldn't leave them...so I had to take them home.
Am I ill??? If so, is there a cure? If there isn't, then don't bother me hahaha... I can't wait till a single 3000p is listed somewhere....maybe I can use it as a center
you have a hobby that spends tons of money for ear pleasure.
The RT1000 will make a fantastic center channel if....
you timbre match it with a left and right pair and can set the center speaker to Large. the center is the hardest working speaker in a surround speaker setup. Invest in a Rat Shack SPL meter and ensure your front 3 speaker levels match and you should hear a huge increase in clairity and separation from the center.
Your only problem is once you've used the 1000 as a center, you'll want matching speakers to increase the detail. Good luck and do yourself a favor and buy your 'better half' something special. -
Hey, I use two towers for my center, don't let em give ya grief.
Like theirs not enough people out to put you down. -
I was looking in the archives and saw you had bought this a while back, do you still have it and are you using it.
I have a blown one and have been looking to replace it but just need one.
Nisqually Dave
