Leaving Amps on 24/7
edited April 2007 in Electronics
How many people leave their SS amps on all the time?
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
Welcome!
    edited April 2007
    My DAC does not have a power switch and is on all the time.
    My preamp and amp both have rocker switches for power. They also have stand by switches; the preamp's is on the face plate while the power amp's is on the back of the unit. The manufacturer recommends they be powered up at all times, which is what I do.
    I also leave the dbx active crossover on as this is connected between the pre and power amps.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
    edited April 2007
    I did not even think about this until now:mad: My amp is in standby mode untill the trigger turns it on.
    Question?
    Does this mean that the caps or whatever is getting juice to it so it is reasonable ready when the trigger turns it on?
    Scott
    edited April 2007
    me me me me me.
    i live my 4 amps all da time. they still work.
    PolkFest 2012, who's going>?
    edited April 2007
    I'm lucky if I get to listen to music 6 to 8 hours aweek, so mine get turned off every time I am done listening. No point wasting electricity, or wearing all the parts out.
    Your caps charge in milliseconds, they have to, as they discharge and recharge constantly when playing music. Your amp will be ready to play right after it is turned on.
    edited April 2007
    SS-on
    edited April 2007
    Mine is on in standby.
    edited April 2007
    With all the crap I've got, it takes so long to turn the thing on that I have no time left to listen since I don't have much time to start with.:D :p
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    edited April 2007
    Used to do it. Then I got to thinking I got away with murder the few times I wasn't around my house but severe thunderstorms were. Too much money involved.
    edited April 2007
    Excellent point GG.
    That said, I leave them on 24/7 as recommended by the manufacturer: LINK
    edited April 2007
    All the time, unless I know I won't use them for a while.... Which is almost never. 4 Adcoms
    Ben
    Ben
    edited April 2007
    Similar question --
    Do you plug your amp directly into the wall? If so, what improvements do you gain by doing so?
    Thanks.
    "God grooves with tubes."
    edited April 2007
    Standby here as well - both amp and pre.
    Michael ;)
    NORTH of 60°
    edited April 2007
    I have my amps turned off and I use a power strip with a 12volt trigger which I made with a relay from radioshack and a transformer plugged into the avr to control it.
    Total cost $12.50 for the entire project...
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
    edited April 2007
    Halo,
    That Sanders amp sounds like it's pretty sharp, and also maybe using some Carver Magnetic Field technology. So small, so light, so powerful, and drawing so little current at idle.
    edited April 2007
    Off, unplugged if there is a chance of threatening weather.
    There isn't a surge box out there that will stop a direct hit. NOT one. It will run straight through fuses and breakers, and cook everything in the path.
    I even make sure the cord is at least a foot away from the outlet, that kind of voltage can jump.
    edited April 2007
    Early B. wrote: »
    Similar question --
    Thanks.
    I run my amps straight to the wall. My GFA-585, 5800, 7500 all draw almost 15 amps max. My GFA-555 draws over 10 amps max. To try to condition or protect that kinda power would be tough. Also if you believe in power cords, and you run them through a protection device you are limited to the capability of the protection device.
    Ben
    edited April 2007
    My outlaw is on standby my marantz always on as they only have a video trigger, which sucks if I only want audio.
    edited April 2007
    My preamp and DAC manuals instruct to leave them on 24/7, and since I've had my rig up (January 7th I think) everything including amps have been continuously on. Unless I was upgrading or biamping. I'm amazed at how cool the Adcom 565s and the Parasound runs. One time and one time only do I remember them getting hot and that was the day it was over 80 degress here and I kept the windows closed while blasting music so I didn't get any outside interference, if ya know what I mean.
    As a matter of fact my Spectral doesn't even have a power switch.
    edited April 2007
    No power switch - WOW! Sorry, for the lack of knowledge, but I'm not sure I would want that. Then again, I never have.
    Michael ;)
    NORTH of 60°
    edited April 2007
    janmike wrote: »
    I spoke to the engineer at Spectral and he said that it should be left on all the time that is why no power switch. It doesn't consume much electricity so that is not an issue. The power amps on the other hand . . .
    edited April 2007
    I shut everything off at night before I hit the sack. I don't want any surprises during the night.
    edited April 2007
    What is the reasoning behind leaving everthing on 24/7?
    If...
    Ron loves a film = don't even rent.
    edited April 2007
    Ron-P wrote: »
    Some equipment reaches a good thermal equalibrium after 1 to 3 days and begins to sound its best. I have a preamp that sounds like crap until its been on for 3 days then it becomes magical. I've had others where it didn's seem to matter. My tube amps get turned on at least an hour before I'm ready to listen because they sound kinda bad until they hit about the hour mark and I won't leave them powered up. Actually, all my tube amps have been that way. My DAC seems to want to be on a few days before it sounds its best too. Until everything else is right none of this really matters. I'd suggest many tries of continuous power and intermittant power to see if you can tell a difference.
    madmax
    Vinyl, the final frontier...
    edited April 2007
    Ron-P wrote: »
    So they stay warmed up and sound up to their full potential. Many solid state devices sound like crap until they warm up. Many also argue that heating up and cooling down causes more wear than just leaving them on all the time. For transistors and ICs, this is probably true, but not for Capacitors and some other passive components that are degraded over time from heat, so its a trade off really and it depends on the device. Items that run hot, I tend to turn off. Items that only get warm or stay cool, I'll leave on.
    My old Sony 333ESL was grainy and awful for the first 5-10 minutes. Although, it had so much Class A bias, it was pretty much fully warmed up in about 15 minutes, after which, it was probably hot enough to slow cook a roast! That said, I didn't leave it on.
    My current Parasound amp, doesn't run quite as hot, but I still don't leave it on. Parasound claims to have special bias circuits that optimize the sound until the amp is warmed up. I can't really hear a difference between the first 5 minutes and after 10 hours, so it must do the job.
    Neither my Preamp or my Tuner get hot at all, so I tend to leave them on for longer periods and often 24/7.
    My CD player does get quite warm, so I don't leave it on. Haven't heard much difference in the sound between warm and cold with it either.
    edited April 2007
    I turn my HT theater equipment off with the exception of the amp which is in standby.
    My 2 channel is turned off also. Around happy hour I usually turn the pre on which powers up a integrated power strip that the rest of my 2 channel is plugged into. I then power up one mono block at a time and let everything warm up for about an hour or so. Usually after dinner I will play a cd at a low level for a warm up while I put the kids to bed and then @ 8-8:30 I come down to have a listen. I usually turn everything off between 10:30-11:30.
    And if I am so inclined, I repeat the above procedure the next day.
    edited April 2007
    What about this ?
    "We believe that a surge protection device should not fail. At the heart of our Series Mode Surge Filter is a massive inductor. This is not a sacrificial component. It will never fail. It will not degrade with use. In fact no component used in the construction of this product is sacrificial. A Brick Wall Surge Filter will never experience a surge related failure.
    You do not have to take our word for it. Consider the following:
    * IEEE (The Institute of Electrical and Electronic Engineers) states that 6000V is the largest transient that the interior of a building would experience.
    * IEEE defines its harshest interior surge environment as one that could experience 100 surges of 6000V, 3000A in a years time (category B3).
    * A new federal guideline recommends that a surge protector utilized in a harsh environment should be capable of withstanding 1000 surges of 6000V, 3000A or ten years worth of IEEEs category B3.
    * UL (Underwriters Laboratories) now provides a new adjunct testing service (in addition to the 1449 safety classification) that will test to the 1000 surge, 6000V, 3000A federal protocol.
    Passing such a test is a virtual guarantee that a surge protection device will never experience a surge related failure.
    Early in 1996 UL applied 1000 surges (at 60 second intervals) of 6000V, 3000A to an off-the-shelf Series Mode Surge Filter.
    There was no failure. There was no performance degradation. Let through voltage did not exceed 400V. Certified by UL.
    We still perform this testing on our equipment today.
    You cannot do any better than this for a point-of-use surge protection device".
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
    edited April 2007
    I just turn my amp off. As soon as I get home I turn everything on have the evening meal, watch the PTI guys, then its off to the shed, works for me.
    RT1
    edited April 2007
    What about this ?
    Who makes this? Got a link?
    edited April 2007
    Lightning is typically between 20,000 and 2,000,000 volts at anywhere from 10,000 up to 200,000 amps.
    It can't be stopped by off the shelf 'protectors'.
    Your link is talking about interior surges IN the building, ie its own devices failing. It has no talk about good ole mother nature.
    Cheers,
    Russ
    edited April 2007
    Ron-P wrote: »
    According to an engineer I spoke to from Spectal it takes time for electronics to stabilize, once they do you don't want to keep disrupting them hence leaving them on 24/7.
Welcome!
Welcome!
