PSW505 - instructions for removing front panel
app2460
app2460 Posts: 3
edited April 2007 in Speakers
One of the connections to the speaker came off when my new sub was being shipped to me. I was able to determine this by removing the back panel. However I cannot reach the terminal on the speaker itself through the back panel. Can anyone tell me how to remove the front panel so I can re-attach the wire to the speaker?
Post edited by app2460 on
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2007
    You could remove the screws for the speaker itself.
  • app2460
    app2460 Posts: 3
    edited April 2007
    Do you know how to do this? Have you seen a schematic?
    After I remove the screen the only thing I see are the plugs for the screen. There are no visible screws or screws behind the plugs. Is this panel glued on?
  • PolkThug
    edited April 2007
    The screws are hiding behind a "gasket" on the rim of the speaker.
  • app2460
    app2460 Posts: 3
    edited April 2007
    Found them, removed the speaker, and re-connected the loose wire.
    Thank you.
  • JeffBowser
    JeffBowser Posts: 17
    edited April 2007
    Hey, question for you - what kind of wire was it leading from the internal amp to the speaker ? Can you figure the guage, type of insulation (if any) ?
    (warning - I have an ulterior motive here.....)
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2007
    I had a stock 505. I guess the guage was around 16, if I was told it was 18 I wouldnt be too surprised, but if I was told it was 14 I wouldnt be surprised either. in other words, it was nothing remarkably thick or thin.
    I modded mine with a defferent driver, polyfill, beefier plate amp, and of course.....12 guage wire :D
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • JeffBowser
    edited April 2007
    Ok, so, we'll say run of the mill 16 guage wire. Mmhm, mmhm.... Thank you.
