PSW505 - instructions for removing front panel
One of the connections to the speaker came off when my new sub was being shipped to me. I was able to determine this by removing the back panel. However I cannot reach the terminal on the speaker itself through the back panel. Can anyone tell me how to remove the front panel so I can re-attach the wire to the speaker?
Post edited by app2460 on
You could remove the screws for the speaker itself.
Do you know how to do this? Have you seen a schematic?
After I remove the screen the only thing I see are the plugs for the screen. There are no visible screws or screws behind the plugs. Is this panel glued on? -
The screws are hiding behind a "gasket" on the rim of the speaker.
Found them, removed the speaker, and re-connected the loose wire.
Thank you. -
Hey, question for you - what kind of wire was it leading from the internal amp to the speaker ? Can you figure the guage, type of insulation (if any) ?
(warning - I have an ulterior motive here.....) -
I had a stock 505. I guess the guage was around 16, if I was told it was 18 I wouldnt be too surprised, but if I was told it was 14 I wouldnt be surprised either. in other words, it was nothing remarkably thick or thin.
I modded mine with a defferent driver, polyfill, beefier plate amp, and of course.....12 guage wire
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Ok, so, we'll say run of the mill 16 guage wire. Mmhm, mmhm.... Thank you.
