In need of amp-pre amp education
Midnite Mick
Midnite Mick Posts: 1,591
Can somebody tell me if there are certain technical type of compatibilities between an amp and a preamp. I am asking in terms of impedance, volts, and other electronic specs that I don't fully understand.
Thanks all,
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Post edited by Midnite Mick on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2007
    Not being smart but seriously......
    Don't sweat the details.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Midnite Mick
    edited April 2007
    So I'll take that as a "no" then :D
    Mike
    Consonance cd120T
    Usher CP 6311
  • disneyjoe7
    edited April 2007
    No but more of why you're worried about it. Or is this more of a nerdy need?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Midnite Mick
    edited April 2007
    I just asked because I have a few concert DVD's that I use my pre/pro with that sounded better before with my Nuforce amps than the tube amps that I just acquired. However, my 2 channel with the Modwright pre sound far better with these amps than they did before with the Nuforce listening to redbook cd. I thought there may be some sort of combatibility issue with the pre/pro and my new amps.....maybe something that I may not be aware of is all.
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • Gaara
    Gaara Posts: 2,415
    edited April 2007
    I know that the impedance is important, you want your amp to have a higher input impedance then your pre, preferably at least 10X. Having a higher input impedance tends to lead to a higher noise on amps though, so they strive for lower input impedances, but then make it difficult to match pres. I am under the impression that if you have a pre with high input impedance and a amp with low input impedance you can have high frequency roll off. Solid state amps generally have lower input impedances say 25kohm-50kohm where tubes are usually closer to 100kohm
    Having a high gain pre with a high gain amp will also lead to more noise. This was part of the issue I had with the Modwright, I had no need for gain as I had a high gain amp + the gain of the Modwright, which is a small part of why I want passive.
    As for volts, you want the output of your pre to be at least the input sensitivity of your amp but not much more then it. If the input sensitivity of the amp was say 1.5v and the output of the pre maxed at 1.0 you would never reach full output on the amp. If the pre was say 2.0 instead then you would reach full output, and could go past that into distortion if turned to high.
    Not sure what else you could look at when mating, spec wise.
    Jared
  • Midnite Mick
    edited April 2007
    Well according to your number Jared everything looks okay......thanks.
    Gives me peace of mind anyway.
    Mike
    Consonance cd120T
    Usher CP 6311
