more speakers or not
rnnwld064
rnnwld064 Posts: 8
onkyotx-ds595 reciever
american research s40's for front
american research s10's for rears
american research rcs25 for center
polk psw450 sub
question is.......should i add another set of fronts to my other speaker outs or not?
Post edited by rnnwld064 on
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited January 2003
    ooooooo, Just plug the speakers up, Mains - To mains A??, Do not play two sets of Mains at once, it'll over drive ur amps....
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • rnnwld064
    rnnwld064 Posts: 8
    edited January 2003
    thanks, what i was needing to know, so moreless 2nd set would be for placing in another room, is this correct?
  • MxStYlEpOlKmAn
    edited January 2003
    Yes, I run my Klh's off the main B's....Just make sure if u use them in anothe room, u turn the ones off in the main room, it will overdrive ur amp sooner than normal and cause clipping - and to answer ur question, main b - is for the other room
    To get to the point, just dont play the two mains at the same time...lmao
    I promised myself
    Damn you all! - ATC
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2003
    American what? You mean Acoustic Research? (former Kloss influenced great, now a Recoton company) Got a pic/link?
    Cheers,
    Rooster
  • MxStYlEpOlKmAn
    edited January 2003
    Originally posted by RuSsMaN
    American what? Got a pic/link?
    Cheers,
    Rooster
    I think he means AR..??? My guess - BTW, arnt they acoustic research?
    I promised myself
    Damn you all! - ATC
  • rnnwld064
    rnnwld064 Posts: 8
    edited January 2003
    American Research.......have cam and will snap ya a pic if ya want
  • MxStYlEpOlKmAn
    edited January 2003
    take pic....
    I promised myself
    Damn you all! - ATC
  • rnnwld064
    rnnwld064 Posts: 8
    edited January 2003
    have pic, and yes acoustic research, been a long nervracking night here.
