which receiver
klove2
klove2 Posts: 38
I recently purchased the monitor 60s speakers and i am not getting the results i expected. I recently had the r30s up front and thought i would hear a big diffrence in the overall sound stage. My feeling is its time to get a new receiver,and that my current yamaha just is not powerful enough to drive them effeceintly. The two receivers i am currently looking at are denon 787 and pioneer vsx 1016 any input or suggestions would be greatly appreciated.
current reciever yamaha 5740
Post edited by klove2 on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    HK or Denon
    You can get refurbs on Ebay real cheap.
    http://stores.ebay.com/Harman-Audio
    Ben
  • Sansui
    Sansui Posts: 372
    edited April 2007
    I just went with a new Denon 887 and even though a lot of it is over my head right now the people here were right, the sound is noticeably better compared to my Onkyo.
    If you go with Denon "word has it here" that the "big" refurb company on E-Bay (dakmart) has the "customer support from hell". If you check the Denon site you can get a list of authorized dealers. (Click on warranty at the bottom of the page, put in your zip code, and then click on "View Authorized Online Dealers".)
    Word also has it here that secondact.biz it a good dealer to buy refurbs from.
    Keep in mind that refurbs are only warranted for 90 days and new ones have a warranty of 2 years. For it to have a warranty it must be bought from an authorized dealer because of serial number tampering.
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • BAD ASP
    BAD ASP Posts: 361
    edited April 2007
    I have never had a HK but I have had an Onkyo and replaced it with the Denon 5700; and that has been in constant use since I purchased it new. I have been extremely satisfied with the operation of the Denon. At the time I purchased the Denon I had researched it thoroughly and was satisfied that it's build was better than similar products from other names we all recognize. I did not want to get into separates at that time as I was unfamiliar with the market, used equipment and my budget wouldn't allow.
    I can highly recommend the Denon that I have and I have looked for the 5700 in the used market and I don't see it being offered FWIW.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • liordra
    liordra Posts: 152
    edited April 2007
    I think that Yamahas are a little bright for the Monitor 60s, just to confuse you further I'd offer http://us.marantz.com/Products/1867.asp# same price point, and I think it gets the best out of the Mon 60s.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    "I just went with a new Denon 887 and even though a lot of it is over my head right now the people here were right, the sound is noticeably better compared to my Onkyo."
    I will have to agree totally with Sansui,
    engtaz
    engtaz
