Fried LSi7?
alan850
alan850 Posts: 3
I think I have really screwed up. Here's the deal. Wife forced divorce of beautifully integrated system. Bridged NAD 55 wpc amps (so in theory 110+ wpc) going into JBL 112's. After 16 years of audio bliss, my wife forced me to get smaller speakers. LSi7's specs say up to 150 wpc, so I bought a pair of LSi7's and moved the JBL's out.
Hooked up the new speakers. My amp manuals talk about "polarity" of speakers and doesn't indicate that getting + and - from amp to speaker is important. In fact, suggests switching + and - if necessary to get best sound.
LSi7 manual says to "be certain" to get + and - correct from amp to speaker.
I didn't pay attention to how + and - were hooked up. Listened to some morning music with the family around at low volume, no problem. Kids off to soccer and I cranked it for the first time (to only 5 on the dial). Good sound for 45 seconds, then both channels started cutting out as my integrated and power amp "protection" features started to kick in and shut down the sound.
Thanks for staying with me this far. Now if I put any volume to speak of to the right speaker, my integrated amp shuts it down. Right speaker has nothing but tweeter and very low volume scratchy woofer. Sounds very bad. I think I had + connected to -. Did I destroy it? Any diagnosis or suggestions for repair? Speakers are dealer "demos" I bought off the web. Thanks in advance.
Post edited by alan850 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Try swapping channels. LSI's are 4ohm speakers, and when you bridge an amp it can only handle half its ohm rating. If your amp can handle 4 ohms stereo than you shouldn't present a 4 ohm load bridged. take your left amp, and hook it up to your right speaker. Let us know what happens.
    Welcome to Club Polk
    Ben
    Ben
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    i think you may have either fried the driver or the crossover in da speaker.
    PolkFest 2012, who's going>?
    F1nut Posts: 52,298
    edited March 2007
    Put another way. Bridged amps are not designed to handle less than 8 ohm loads + the Polk's are 4 ohm speakers = bad juju.
  • alan850
    alan850 Posts: 3
    edited March 2007
    I switched amp hookups and have the same problem with the same speaker. I think it is the speaker. If some component of the speaker is fried, how big a deal is this to fix? Is my only option to send it back to Polk or is this something I can fix. Thanks, again, in advance.
  • ben62670
    edited March 2007
    Call Polk customer service, and they can help you. They have the best customer support I have ever dealt with. Mention that you are a Club Polk member too.
    Ben
