Subwoofer timing?
soiset
soiset Posts: 724
edited March 2007 in Car Audio & Electronics
I think this is my first post in the car audio section. Don't know why I didn't think of asking about this before.
I have a Subaru Impreza wagon. Head unit is a Clarion DXZ825, DSP is Clarion DPH910, CD changer is CDC1255Z. Amp is Rockford Fosgate Power 600.5. Fronts are Polk db3055, rears are db4510. Sub is the previous generation Polk db10 in a 1 cubic foot sealed box, behind the back seat in the cargo area.
The problem I have always had is that the lowest bass from my sub sounds delayed, as though it is arriving a fraction of a second late to my ears. This is particulary noticeable with electronic music, with its much lower and more prevalent bass. Not so much with regular rock.
There is no delay or phase function on the head unit, dsp, or amp.
Anything I can do about this? Is it possible it isn't a delayed arrival, but something else?
Post edited by soiset on
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2007
    Try wiring the sub out of phase. This sometimes helps.
  • soiset
    soiset Posts: 724
    edited March 2007
    Hmm, hadn't thought of that. Isn't that supposed to kill the bass? Of course, it's not hard to try! Is this exactly the same as a phase switch being set to 180?
  • soiset
    soiset Posts: 724
    edited March 2007
    Actually, even tho it is raining, I'm going out there to try it now!
  • MacLeod
    edited March 2007
    Yup, its the same as 180 degrees out of phase.
    Doesnt always work, in fact it usually doesnt. However I currently have the sub out of phase in my car now. It does pull the bass up front AND add to the response.
  • Jack from Indo
    Jack from Indo Posts: 109
    edited March 2007
    I'm just a noobie, but about a year ago I had the same problem - well, I would have described it the same, anyway. I was using a RF sub, but underpowering it.
    Upping the watts with a diff. (JL 500.1) amp fixed it. I wonder if this had something to do the better slew rate, and/or damping factor, as well as more watts?
  • Toxis
    Toxis Posts: 5,116
    edited March 2007
    more power won't make the sub react faster vs delayed.
    Mac - I see the bass moving "up front" but adding to the response? How is that possible? Same settings, same sub, same box. How did phase affect the response??
  • soiset
    soiset Posts: 724
    edited March 2007
    I tried wiring it out of phase, and I can't say that it worked. I'm really disappointed that my ultra-fancy DSP doesn't accomodate time alignment. My sub is several feet farther from my ears than my mains, and is crossed at about 100 Hz. In a home system, the barest of AV receivers now have delay for all of the speakers. I figure that the sub sound arrives to my ears 3 milliseconds (roughly 3.5 feet farther) after the main sound. I did notice much improved sound last time I travelled with so much stuff in the car that I had to put the sub behind the passenger seat in the floor, making it about the same distance to my ears as my mains.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited March 2007
    No... the only thing that you would have noticed was the added power, and this would be if you came close to doubling your power.
    Depends on the install.
    Have you tried playing aound with the way the sub is firing?
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • soiset
    soiset Posts: 724
    edited March 2007
    I take it you mean the direction it faces(?)
  • 1996blackmax
    edited March 2007
    Correct....
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited March 2007
    It wont add to your response, but if youre sub is playing a couple of ms behind the rest of your speakers, and reversing the polarity happens to help, youre going to be getting the right sound at the right time making it seem like it has a fuller response...hope that makes sense. lol.
    -Cody
  • Toxis
    Toxis Posts: 5,116
    edited March 2007
    lol no it didn't. Timing of the bass wave is different than the response.
