Upgrading Polk 10s
Sumbrada77
Sumbrada77 Posts: 37
edited April 2007 in DIY, Mods & Tweaks
I want to redo, upgrade my original Monitor 10s. Crossovers, possible tweeters. Any help?
1. Suggestions on Caps? I have heard good things for Solens and Sonicaps.
what's your opinions?
2. What I read, a 0.1uF ish bypass Cap with the main caps really help detail and smoothness. Opinions? Suggested values?
3. Should the Mylar 12uF be switched with Solens type along with the Electrolytics? If not, suggestions for the Mylar?
4. Everyone suggests Mills resistors, how about the inductors/coils?
5. In the schematics available here there are 2 mods. One for the SL2500 tweeters. Values are different. Any help on Why? I have Peerless now but maybe upgrading to the RDO silks later.
CARPE CEREVISI!!
A Wise man, Keeps his Friends close, but keeps his
Enemies Closer !!
Yamaha RX-V659 A/V receiver, Maganox CDP482 CD,
Pansonic DVD F85, Marantz 6300 TT w/Apature KOCE
Polk 10s (mains), M&K 3B (backs), Polk 5b Center
HSU Research VTF-2 Mk1 subwoofer
DIY twisted speaker cable
Post edited by Sumbrada77 on
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2007
    Hi! Welcome to Club Polk! If you have Peerless tweeters, don't worry about getting the silks. Your Peerless are just fine. If you want to upgrade the components on the crossover, use either Sonicaps or Solens. The Sonicaps cost more, but I think they sound better. If you use Sonicaps you won't need a bypass cap, it will sound fine without it. If you want to use a bypass, go ahead and use a 0.1 uF Gen II Sonicap. Get yourself some new binding posts. Vampire binding posts will cost you about $25 for a stereo pair. Get the short or the long ones. Do you have stands for your Monitor 10's? If so, put some spikes on them to tighten up the bass.
    Good luck and welcome to the Club Polk Forums!
    Carl
  • schwarcw
    edited March 2007
    I looked at the Monitor 10 schematic. Don't touch the inductors, they should be okay. I would get a Solen cap for the 34 uF and Sonicaps for the 12 uF caps. There are no bypass caps in the original schematic. I wouldn't add one. If you play your music at reasonable volume levels with a good amp, you can remove the Polysitches and use a jumper in it's place. A piece of 14 gauge copper wire will do. Mill resistors are very good and inexpensive.
    Good luck!
    Carl
    Carl
  • Sumbrada77
    edited April 2007
    Thanks for the information. I do have the Polk stands. You suggest
    spikes, I will have to try it as they do stand on carpet. You suggest
    Solens for all or the 34uF and Sonicap for the 12uF. No problem
    about leaving the coils alone. That was I was figuring also. Yea new binding posts are in the plans, the originals are poor. I have the early version with a fused tweeter so I do not need to jumper (I don't think?). After pulling the drivers to redo the crossovers what do you suggest to seal the cabinets
    again. Silicone sealant?? thanks again!
    CARPE CEREVISI!!
    Enemies Closer !!
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2007
    Drivers and binding posts cup should have a seal; use that same one.
    SOPA
