A requirement for every tube owner...
VR3
Whether you have an amp, preamp or CDP, or multitudes of both - a nice fan is a requirement during summer months.
Who knew you could find a fan that could match your speakers AND your gear??
Not to bad for 50 bucks at Walllly Mart
Post edited by VR3 on
Nice! Now you can point the fan to keep your electronics cool.
Haha, yeah - but heck it was 85 degrees in my room the other night. Talk about uncomfortably hot for a 10.5x10.5 room??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Very nice Trey
Vr3MxStyler2k3 wrote:Haha, yeah - but heck it was 85 degrees in my room the other night. Talk about uncomfortably hot for a 10.5x10.5 room??
Quit whacking off so much.Political Correctness'.........defined
President of Club Polk -
WAAAAAAAAAAAAAAAAAAAAAAAAAAa I just got that picture!!!
Vr3MxStyler2k3 wrote:Whether you have an amp, preamp or CDP, or multitudes of both - a nice fan is a requirement during summer months.
Trey is it quiet? -
hearingimpared wrote:Trey is it quiet?
No....he moans alot.....Oh...you mean the fan???:DHT SYSTEM-
lsi 9's -
You guys crack me the eff up!!!
Haha - you guys are a riot. lol
Is it quiet?
Id say at full speed - its probally at about the volume of someone softly talking....
you can easily drown it out with a little music or something of the sort.
But in my small room, speed 1 is pretty significant shift in temperature, much less 3.
Compared to a massive 12" fan or something Ive had in here before - its far quieter in air movement and general operation.
Having a remote and a timer is a neat trick too... and some time of Ion thingy.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
http://www.laskoproducts.com/fans/model_2554.html - heres the one I got here...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Vr3MxStyler2k3 wrote:http://www.laskoproducts.com/fans/model_2554.html - heres the one I got here...
I'm glad you posted that cause it was my next question. How's it do with static? Does it increase it or decrease it or no affect at all? -
hearingimpared wrote:I'm glad you posted that cause it was my next question. How's it do with static? Does it increase it or decrease it or no affect at all?
Damm Joe if it gets rid of static you need to buy 3:D
:eek: -
I havnt particularly noticed an increase of static...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You got that right. No sooner than I take a record just cleaned off the 16.5, and carry it over to the turntable I can see bits of dust flying through the air trying to attach themselves to the record. Then I have to us the ion gun to get rid of the static and then have to run the carbon fiber brush across the just cleaned record. . uh it can be exhuasting but it is worth every bit of work once that record starts to play.Fireman32 wrote:Damm Joe if it gets rid of static you need to buy 3:D
:eek:
And for the record my wife is a clean freak so no dirty house jokes!!! -
For what its worth, this thing has a built in ION thingy...
I have not got my Candela yet - will be in about 3-4 months, give or take...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I have thingy too. when ION something my thingy becomes a door-knocker
Joe the 16.5 puts static on the record, you need a watts preener or some such brush.
RT1 -
reeltrouble1 wrote:I have thingy too. when ION something my thingy becomes a door-knocker
RT1
Ted don't those types of brushes leave some residue? -
Just think how that sucker will work once you upgrade the PC!!!!:D Talk about cooling off a room!
hearingimpared wrote:Then I have to us the ion gun to get rid of the static and then have to run the carbon fiber brush across the just cleaned record. . uh it can be exhuasting but it is worth every bit of work once that record starts to play.
That is weird. My house is a freakin dust bowl and I never see that. BTW, I am an anti-clean freak.
+1, im on the local anti-clean agency....i cant live in an orderly manner.....
:rolleyes: -
My room stays pretty much spotless...
Granted if a pen falls on the floor - that would limit your walking area about 80%
Vr3MxStyler2k3 wrote:My room stays pretty much spotless...
Yea I hear living in a washing machine cardboard box is hard to do.....you should try to upgrade to a refrigerator box.
You should start building your furniture with ladders and walkways over it this way you can keep expanding.
You're in North Carolina? Why don't you have Air Conditioning??
I could understand if it was Mississippi, but damn. :eek: -
hearingimpared wrote:Ted don't those types of brushes leave some residue?
I've used the Watts Preener and like it. I prefer the Hunt brush better though.
Also, if you are using the VPI brush, pitch it. Get the MFSL brush. It's MUCH better.
Im shooting you all with my Zerostat at the next PF.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
shepx2 wrote:You're in North Carolina? Why don't you have Air Conditioning??
We have air conditioning...
My room is usually about 5-10 degrees hotter in than the rest of the house though...
Its a blessing in the winter and a torture in the summer
TroyD wrote:I've used the Watts Preener and like it. I prefer the Hunt brush better though.
BDT
I use the VPI brush to apply two of the four fluids, I then finish with the MFSL brush with the final fluid.
Watss Preener & Hunt brushes. Are these used during the wet / vac process or when the record is on the turntable ready to be played? -
I use the preener when the record is on the table.
RT1 -
reeltrouble1 wrote: »I use the preener when the record is on the table.
RT1
I have a carbon fibre brush (the spelling is correct) that I received from a fellow from Canada. I use it when the record is on the table. What I want to know is do the preeners get rid of the static on the record on the turntable? That is where my problem lies after I use the carbon fibre brush. It causes static and this static discharge manifest themselves as ticks and pops. How I know this is that when listening to a record I hear the ticks and pops in certain places. When I listen again, those ticks and pops are not there. . . mostly rainy days when the air is full of moisture.
