A requirement for every tube owner...
VR3
VR3 Posts: 29,427
edited April 2007 in The Clubhouse
Whether you have an amp, preamp or CDP, or multitudes of both - a nice fan is a requirement during summer months.
Who knew you could find a fan that could match your speakers AND your gear??
Not to bad for 50 bucks at Walllly Mart
fan.jpg 133.3K
Post edited by VR3 on
  • MikeC78
    MikeC78 Posts: 2,315
    edited March 2007
    Nice! Now you can point the fan to keep your electronics cool.
    VR3 Posts: 29,427
    edited March 2007
    Haha, yeah - but heck it was 85 degrees in my room the other night. Talk about uncomfortably hot for a 10.5x10.5 room??
  • Fireman32
    Fireman32 Posts: 4,845
    edited March 2007
    Very nice Trey
    F1nut Posts: 51,763
    edited March 2007
    Quit whacking off so much.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    WAAAAAAAAAAAAAAAAAAAAAAAAAAa I just got that picture!!!
  • hearingimpared
    edited March 2007
    Trey is it quiet?
    tonyb Posts: 33,072
    edited March 2007
    Trey is it quiet?
    No....he moans alot.....Oh...you mean the fan???:D
  • hearingimpared
    edited March 2007
    You guys crack me the eff up!!!
    VR3 Posts: 29,427
    edited March 2007
    Haha - you guys are a riot. lol
    Is it quiet?
    Id say at full speed - its probally at about the volume of someone softly talking....
    you can easily drown it out with a little music or something of the sort.
    But in my small room, speed 1 is pretty significant shift in temperature, much less 3.
    Compared to a massive 12" fan or something Ive had in here before - its far quieter in air movement and general operation.
    Having a remote and a timer is a neat trick too... and some time of Ion thingy.
    VR3 Posts: 29,427
    edited March 2007
  • hearingimpared
    edited March 2007
    I'm glad you posted that cause it was my next question. How's it do with static? Does it increase it or decrease it or no affect at all?
  • Fireman32
    edited March 2007
    Damm Joe if it gets rid of static you need to buy 3:D ;) :eek:
    VR3 Posts: 29,427
    edited March 2007
    I havnt particularly noticed an increase of static...
  • ninerbj
    ninerbj Posts: 870
    edited March 2007
    The Candela that is?
    "she had the body of Venus, with arms."
  • hearingimpared
    edited March 2007
    You got that right. No sooner than I take a record just cleaned off the 16.5, and carry it over to the turntable I can see bits of dust flying through the air trying to attach themselves to the record. Then I have to us the ion gun to get rid of the static and then have to run the carbon fiber brush across the just cleaned record. . uh it can be exhuasting but it is worth every bit of work once that record starts to play.
    And for the record my wife is a clean freak so no dirty house jokes!!!
    VR3 Posts: 29,427
    edited March 2007
    For what its worth, this thing has a built in ION thingy...
    I have not got my Candela yet - will be in about 3-4 months, give or take...
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2007
    I have thingy too. when ION something my thingy becomes a door-knocker
    Joe the 16.5 puts static on the record, you need a watts preener or some such brush.
    RT1
  • hearingimpared
    edited March 2007
    RT1
    Ted don't those types of brushes leave some residue?
  • pearsall001
    pearsall001 Posts: 5,289
    edited March 2007
    Just think how that sucker will work once you upgrade the PC!!!!:D Talk about cooling off a room!
  • madmax
    madmax Posts: 12,434
    edited March 2007
    That is weird. My house is a freakin dust bowl and I never see that. BTW, I am an anti-clean freak.
    madmax
    Vinyl, the final frontier...
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited March 2007
    +1, im on the local anti-clean agency....i cant live in an orderly manner.....
    :rolleyes:
    VR3 Posts: 29,427
    edited March 2007
    My room stays pretty much spotless...
    Granted if a pen falls on the floor - that would limit your walking area about 80% ;)
  • BaggedLancer
    edited March 2007
    Yea I hear living in a washing machine cardboard box is hard to do.....you should try to upgrade to a refrigerator box.
    You should start building your furniture with ladders and walkways over it this way you can keep expanding. :p
  • shepx2
    shepx2 Posts: 646
    edited March 2007
    You're in North Carolina? Why don't you have Air Conditioning??
    I could understand if it was Mississippi, but damn. :eek:
  • TroyD
    TroyD Posts: 13,124
    edited March 2007
    I've used the Watts Preener and like it. I prefer the Hunt brush better though.
    Also, if you are using the VPI brush, pitch it. Get the MFSL brush. It's MUCH better.
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    Im shooting you all with my Zerostat at the next PF.
    VR3 Posts: 29,427
    edited March 2007
    We have air conditioning...
    My room is usually about 5-10 degrees hotter in than the rest of the house though...
    Its a blessing in the winter and a torture in the summer :)
  • hearingimpared
    edited March 2007
    BDT
    I use the VPI brush to apply two of the four fluids, I then finish with the MFSL brush with the final fluid.
    Watss Preener & Hunt brushes. Are these used during the wet / vac process or when the record is on the turntable ready to be played?
  • reeltrouble1
    edited April 2007
    I use the preener when the record is on the table.
    RT1
  • hearingimpared
    edited April 2007
    RT1
    I have a carbon fibre brush (the spelling is correct) that I received from a fellow from Canada. I use it when the record is on the table. What I want to know is do the preeners get rid of the static on the record on the turntable? That is where my problem lies after I use the carbon fibre brush. It causes static and this static discharge manifest themselves as ticks and pops. How I know this is that when listening to a record I hear the ticks and pops in certain places. When I listen again, those ticks and pops are not there. . . mostly rainy days when the air is full of moisture.
