VMPS Quality Control
VR3
The Larger Subwoofer is freaking amazing. And Im glad to listen to it again after hearing a SVS Ultra all weekend.
The VMPS definitely rocks its socks in music....
But, I received my new base today since the original they sent was to large for the larger... haha
Anyways, so I inspect is - there is 3 gashes about .25" wide, back to back to back on one side - and a minor gash on the back. Not very deep, maybe a 1/16" deep - but the smooth finish had come off.
So what do they do? They fill it in with permanent marker and send it my way.
Im not exactly mad, because it is just the base and the cabinet is spotless.
But still, new is new is new right?
Post edited by VR3 on
So Brian emails me back....
And tells me the base is from a pre-existing subwoofer... and they fill in any blemishes...and should not be visible when installed
Hmmm...
Im really trying to be polite here with him and have been so far..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would politely remind him that you paid for a new subwoofer and expect all parts on that subwoofer to be new.
If he refuses let him know that the last used VMPS subwoofer that sold on club polk sold for $200 and you would be glad to match that price for his used sub. (ok, so that was an original, not the larger so maybe go as high as $300)
I purchased brand new.
Here is the email I sent him...
Hey Brian,
Thanks for your fast response.
It makes sense that the unit would have blemishes then. I appreciate your upfront honesty. On the next subwoofer, please notify me that I will be purchasing a B stock unit before hand. This way I can expect blemishes. I was under the impression this unit was 100% new.
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Attached some pics...
There is also a ring of MDF on the exterior bottom where the paint had been wore off. They filled in 2 of the sides in on the bottom with perm marker, one side was not filled in and you can see the bottom line of MDF where the paint ends...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I also just noticed that on every corner the finish is cracked in two vertical lines.
I requested a new base.
*argh*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thats really screwy. One should usually expect a higher level of CS from a smaller company.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Everything else is fantastic. Brian responds within 20 minutes most of the time until about 12 oclock EST, so I am waiting till tommorow for a response.
The enclosure which weighs a blistering 90 pounds on its own empty is grade A.
Boggles my mind that I cant seem to get the right piece for the unit that probally cost 15 bucks to make....
All I want is a brand new base, that fits - with no marks.
The first base he sent me was close to my specifications, it was just to big.... lol
*sigh*
The least he could do is take the other base back, fill in the blemishes with puddy, sand the entire thing down and repaint it.
And at that point it would be cheaper to just make me a new one.
Ah well, I requested a new one after sending him pics of the unit. So shall see.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sounds way too obvious to me. Hopefully things work out.Michael
NORTH of 60° -
The least they could do is try to carefully paint it, magic marker is just pathetic.
Just the audacity of using a permanent marker tells me that they probably get away with it all the time.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
VMPS's cabinets have ALWAYS been a roll of the dice, much better now than in the past. Not saying it is right or anything, but there are many threads about poor quality fit and finish.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Yeah, thats what Ive been told. I will keep requesting a new base until I get one that is new. Period. Its one thing to have a slight blemish - but to have the balls to send me a USED base...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
And you are right; just mention what Club Polk can do to bad Customer Service...._________________________________________________
Let us know how they go about fixing this issue.
Good Luck,
engtazengtaz
I am absolutely stunned. This sort of customer service is beyond unacceptable. Actually, "illegal" is the first thing that comes to mind. Plus, we're talking about the audio community here -- individuals not prone to easily dismissing the misrepresentation of an item's condition. Much less a NEW item's condition.
Pathetic and alarming. Sid, I hope you not only get what you paid for out of this debacle, but a sincere apology as well.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
I never ubderstand whats so hard about treating people right? If I had to wager a guess, since they are small, they just dont have the base right now, hence having to get a used one.....in that condition, where the hell did they dig that thing out of?
whats so hard about sending an email something like this
Dear Trey,
I am in the unfortunatle situation to be unable to send you a base for your sub. I enclosed a used piece that you can use so that you can you can have function of your subwoofer. I will get you the new piece as soon as humanly possible. I am very sorry for the inconvenience.
I could make it sound better with more time, but I'm sure you get the gist.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
That's definitely a step in the right direction...
I would also ask that he provide a steady stream of updates regardless of whether or not the base is in transit.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
I dont think I will have any problems. Shall see.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
ZB nailed it. This is totally unacceptable & deceptive. What part of NEW do they NOT understand? They took you money for a NEW product, that is what should be sent!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
sounds like the sub is new, just for some odd reason, they dont have a new base available. wierd things like this can happen with a small outfit, which I assume they are. this might have been a new old stock item. new, but no longer in production. I have a feeling thats the problem.
hopefully will be rectified, as you should have a new, unblemished, base for this thing.Living Room 2 Channel -
ohskigod wrote:this might have been a new old stock item. new, but no longer in production. I have a feeling thats the problem.
Yep. They have recently introduced new subwoofer models. Of course, that's no excuse. Hell, it's just a slab of MDF, isn't it?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
The Larger Sub w/ megawoofer is still in production. They introduced two new models in different price brackets though.
They are sending me a new base. Numero Three!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote:They are sending me a new base. Numero Three!
If they're sending you a new one, it must mean they have new ones in stock. So why did they send you an used one?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
No idea, Brian also did not apologize for the incident either.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I mean... why should he? It's amazing how such an eazy fix can be so easily dismissed. Eff goin' the extra mile. It's as if he doesn't believe in his product at all. I wouldn't be surprised to find out he drives a white van to work:D
Trey... that's not a slam against the VMPS. It just seems to be such wasted potential if this experience is par for the course.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Who knows.
VMPS has been in business for 30 years...
Makes their own drivers, etc... the sub is fantastic - one of the best - and Ive heard alot of subs.
Who knows - the verdict will be what he sends me next- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I hope all works out... maybe he'll get tanked on grog tonight, get all weepy eyed and send you an even bigger sub. And a chocolate rose.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
lol....
Couldnt fit a much larger beast in here -
Ill take the array that weighs 300 pounds aha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So, in your opinion, how does it compare to the SVS ultra?
Glad to hear things are being straightened out._________________________________________________
