5Y3 rectifier tube glows blue...Normal?
cbl117
cbl117 Posts: 285
edited March 2007 in Electronics
I have a question reguarding a guitar amplifier. when I turn on the amp the rectifier tube glows blue for about a second. After a second the blue glow disappears. The amp sounds fine and everything functions. Is this tube bad? The amp was just serviced, and the tube is a NOS 5Y3.
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Post edited by cbl117 on
  • Ricardo
    Ricardo Posts: 10,634
    edited March 2007
    I've seen many tubes glow blue continuously; never thought it was a problem. And looks cool.
    SOPA
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2007
    It will most likely be okay, but the life of this rectifier tube may be shortened. BTW, no real reason to use NOS for the 5Y3. You probably have 12 AX7s and 6L6GCs in the same amp and they make more difference in the sound than the rectifier does.
  • cbl117
    cbl117 Posts: 285
    edited March 2007
    yep I have one 12ax7 and one 6v6. The amp I'm talking about is a vintage fender champ. neat little amp, single ended 5 watt monster.
    Vandersteen 3a Sigs
    Hovland HP-100
    Rotel RCD-1072
    PS Audio UPC-200HB
  • Dennis Gardner
    edited March 2007
    I like vintage Fender amps. I have 2 Twin Reverbs in the shop for repair as we speak.
  • cbl117
    cbl117 Posts: 285
    edited March 2007
    Nice amps! I've had my heart set on a deluxe reverb or a tweed princeton. Nothing beats vintage fender grit.:D
    Vandersteen 3a Sigs
    Hovland HP-100
    Rotel RCD-1072
    PS Audio UPC-200HB
  • Ricardo
    edited March 2007
    A bit more info; it is normal.
    http://members.aol.com/larrysb/blue_glow.html
    SOPA
