5Y3 rectifier tube glows blue...Normal?
cbl117
I have a question reguarding a guitar amplifier. when I turn on the amp the rectifier tube glows blue for about a second. After a second the blue glow disappears. The amp sounds fine and everything functions. Is this tube bad? The amp was just serviced, and the tube is a NOS 5Y3.
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Post edited by cbl117 on
I've seen many tubes glow blue continuously; never thought it was a problem. And looks cool._________________________________________________
It will most likely be okay, but the life of this rectifier tube may be shortened. BTW, no real reason to use NOS for the 5Y3. You probably have 12 AX7s and 6L6GCs in the same amp and they make more difference in the sound than the rectifier does.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote:It will most likely be okay, but the life of this rectifier tube may be shortened. BTW, no real reason to use NOS for the 5Y3. You probably have 12 AX7s and 6L6GCs in the same amp and they make more difference in the sound than the rectifier does.
yep I have one 12ax7 and one 6v6. The amp I'm talking about is a vintage fender champ. neat little amp, single ended 5 watt monster.2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Black Diamond Racing Isolation -
I like vintage Fender amps. I have 2 Twin Reverbs in the shop for repair as we speak.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Nice amps! I've had my heart set on a deluxe reverb or a tweed princeton. Nothing beats vintage fender grit.:D2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
