First attempt at Bi-wiring
Jet_olson
I have to say ladies and gents that I just setup my RTi8's using biwiring and I have to say there is a difference! I was the biggest skeptic but I must admit it definately is clearer and more defined....I wouldnt have believed it until I tried it myself...
Call me crazy!
Good stuff!
Call me crazy!
Good stuff!
Rec: Yamaha RX-V659
L/R: Polk Audio RTi8's
C: CSi3
RSurrounds: TC610i's
Sub: Hsu Research STF-2
Showcase:
http://www.polkaudio.com/forums/showcase/view.php?userid=78895
Post edited by Jet_olson on
Stop smokin' that stuff. You are crazy!:p~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Be careful Jet,
It is a slippery slope and Bi-wiring is the Gateway Modification to the hard stuff.:D
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
MillerLiteScott wrote:Be careful Jet,
Yep,, the path that you are headed upon will reveal many temptations of biblical proportions,,beware that some "never return" :cool:
JC approves....he told me so. (F-1 nut) -
is it strange that I am now having dreams of adding pre-amps and taking my floorstanders to dinner?
Rec: Yamaha RX-V659
C: CSi3
Showcase:
http://www.polkaudio.com/forums/showcase/view.php?userid=78895 -
Nah... it only gets strange when you start expecting "to get some" after you spring for the dinner.
Enjoy...More later,
Tour...
Vox Copuli
I am about to try this myself for the first time, to Bi-wire a set of RT55s.
When I do this, I thought could either "double up" the connection at the amp end, or, since my "B" speaker terminals are not is use, it would be easier to just use those.
Would either way be better? -
I doubled up at the amp.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
I finished Bi-wiring my RT55's and CS400.
I replaced single (non-bi-wired) 16 guage wire with dual sets of 14 gauge wire.
Unfortunately, I could not hear any difference. -
Listener10 wrote:I am about to try this myself for the first time, to Bi-wire a set of RT55s.
I'd use the B speaker Terminals because in most cases its pretty cramped back there. for that reason I also preferred Banana's. -
Does anyone have any pictures of their bi-wiring? I was going to attempt this today and was reading up on it but I was not able to find a pic of what it actually looks like.
Thx -
it's extremely easy to do.. first off. unplug or turn off your amp/receiver. remove the jumpers from your speakers, run two sets of speaker wire from your receiver/amp - two wires on the red, two wires for the black.. then at the speaker end... just seperate them.. one each for the black posts, one each for the red posts. turn on receiver and enjoy.PolkFest 2012, who's going>?
Sounds easy enough. I actually did find a few pics scrolling through some other threads here like I probably should of done before posting the question.danger boy wrote:it's extremely easy to do.. first off. unplug or turn off your amp/receiver. remove the jumpers from your speakers, run two sets of speaker wire from your receiver/amp - two wires on the red, two wires for the black.. then at the speaker end... just seperate them.. one each for the black posts, one each for the red posts. turn on receiver and enjoy.
But thanks nonetheless!
Jet_olson wrote:I have to say ladies and gents that I just setup my RTi8's using biwiring and I have to say there is a difference! I was the biggest skeptic but I must admit it definately is clearer and more defined....I wouldnt have believed it until I tried it myself...
Call me crazy!
Good stuff!
Sounds like you're having fun. Now try a single run of 10awg.
