SVS 20-39 PC plus and a PSW505
blacklab
blacklab Posts: 37
I'm currently running the PSW505 but am going to order the SVS 20-39 PC plus sub. My room is 18'x17', 9 foot ceiling. My question: should I set up dual subs, or will the PC+ be more than sufficient, and move the PSW505 to a new location, or sell it. I'm not opposed to big bass, but am opposed to wasting a good subwoofer.
Post edited by blacklab on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2007
    I would sell it. I don't think that they will sound good together at all. Sell it and put the $$$ toward another SVS.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • blacklab
    blacklab Posts: 37
    edited March 2007
    Very nice setup Wingnut. If my end product turns out to be 3/4 that sweet I'll be very happy. Thanks for the sub input.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Before you sell try setting th XO on the SVS at 50, and the XO on the Polk at 80. Use an SPL meter ($50 at radio shack) and test your room frequency. If you are a music lover you may just want to use the svs, for HT try both. You have a big room:D
    Ben
  • wingnut4772
    edited March 2007
    Thanks. Wish it was still all there.
    Ben is right. Try both first. Maybe you will like it but another SVS would be better.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • McLoki
    McLoki Posts: 5,231
    edited March 2007
    Chinup WingNut - your next system you will get to listen to / watch with a smile on your face. That will make any gear you have that much nicer.
    Michael
  • Ricardo
    Ricardo Posts: 10,634
    edited March 2007
    Try the SVS by itself; for your room size you really won't need any more bass (though you might "want" more :))
    SOPA
  • blacklab
    blacklab Posts: 37
    edited March 2007
    Would a Y splitter at the AVR sub out be the best option for dual?
  • bassaholic
    bassaholic Posts: 315
    edited March 2007
    I run a Polk and an SVS in my set-up and couldn't be happier. My room is 17x14 8ft ceilings. Try-um both via the y-splitter you mentioned (thats the way I do it) I think you'll be happy as well.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • blacklab
    blacklab Posts: 37
    edited March 2007
    Does the Y splitter manuf. make much of a difference for signal purposes? I'm looking at one from bluejeans (inexpensive) to go along with a 400 ft. order of CL3 12awg.
  • blacklab
    blacklab Posts: 37
    edited March 2007
    okay - if I decide to hook them both up and set the XO on SVS to 50 and the Polk to 80, what is the best way to hook them together? If I use the LFE in, will I not lose the subs internal XO and will it be impossible to set the 2 subs at 50 and 80 seperately? (sorry for the newbie questions, but I cannot find this info. on the forum):confused:
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2007
    The 20-39+ has a xover switch. Y out of the subout to both subs, set the crossover on the pre/pro to 80hz. Set the xover on the SVS to 50 (be sure the switch is enabled). Either disable the xover on the 505 or turn it all the way up (not familiar with the amps controls). That should do it. If you split them FR response will be different for each sub and calibration will be tricky.
    Let us know how it sounds.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • ben62670
    edited March 2007
    What he said, and play with the XO's. It would also help knowing what your mains are. If they are smaller drivers you may want to go as high as 120 on the Polk. Nothing is set in stone here. Play with both. Every sub, and room(not just size) is different. Most likely you will want to put the SVS in a corner if you are running the polk higher. Listen a while with different setups, then decide if you want to sell the Polk.
    Ben
  • blacklab
    blacklab Posts: 37
    edited April 2007
    I've now recently received the SVS 20-39 pc+ and have set it up properly with the RS SPL. Anyone reading this, and is thinking of matching this sub to a psw505 for dual subs....well....don't waste your time. Drop the psw505 asap and stick with svs. This is the cleanest, most powerful bass that I have ever heard. Where did all the boominess go? I'll tell you....to a buyer on e-bay!!! As most of you know, and as I've recently discovered, these subs cannot be compared fairly as they are in totally different realms of SQ. Hands down, best HT purchase to date. :D
  • Ron Temple
    edited April 2007
    Kinda thought this would be your conclusion. There's no similarity to each other's sound signature. It probably would have muddied up your room. Enjoy your sub. :D
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
