SVS 20-39 PC plus and a PSW505
blacklab
I'm currently running the PSW505 but am going to order the SVS 20-39 PC plus sub. My room is 18'x17', 9 foot ceiling. My question: should I set up dual subs, or will the PC+ be more than sufficient, and move the PSW505 to a new location, or sell it. I'm not opposed to big bass, but am opposed to wasting a good subwoofer.
Post edited by blacklab on
I would sell it. I don't think that they will sound good together at all. Sell it and put the $$$ toward another SVS.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Very nice setup Wingnut. If my end product turns out to be 3/4 that sweet I'll be very happy. Thanks for the sub input.
Before you sell try setting th XO on the SVS at 50, and the XO on the Polk at 80. Use an SPL meter ($50 at radio shack) and test your room frequency. If you are a music lover you may just want to use the svs, for HT try both. You have a big room:DPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
blacklab wrote:Very nice setup Wingnut. If my end product turns out to be 3/4 that sweet I'll be very happy. Thanks for the sub input.
Ben is right. Try both first. Maybe you will like it but another SVS would be better.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote:Thanks. Wish it was still all there.
Chinup WingNut - your next system you will get to listen to / watch with a smile on your face. That will make any gear you have that much nicer.
Try the SVS by itself; for your room size you really won't need any more bass (though you might "want" more )_________________________________________________
Would a Y splitter at the AVR sub out be the best option for dual?
I run a Polk and an SVS in my set-up and couldn't be happier. My room is 17x14 8ft ceilings. Try-um both via the y-splitter you mentioned (thats the way I do it) I think you'll be happy as well.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
Does the Y splitter manuf. make much of a difference for signal purposes? I'm looking at one from bluejeans (inexpensive) to go along with a 400 ft. order of CL3 12awg.
okay - if I decide to hook them both up and set the XO on SVS to 50 and the Polk to 80, what is the best way to hook them together? If I use the LFE in, will I not lose the subs internal XO and will it be impossible to set the 2 subs at 50 and 80 seperately? (sorry for the newbie questions, but I cannot find this info. on the forum)
The 20-39+ has a xover switch. Y out of the subout to both subs, set the crossover on the pre/pro to 80hz. Set the xover on the SVS to 50 (be sure the switch is enabled). Either disable the xover on the 505 or turn it all the way up (not familiar with the amps controls). That should do it. If you split them FR response will be different for each sub and calibration will be tricky.
Let us know how it sounds.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote:The 20-39+ has a xover switch. Y out of the subout to both subs, set the crossover on the pre/pro to 80hz. Set the xover on the SVS to 50 (be sure the switch is enabled). Either disable the xover on the 505 or turn it all the way up (not familiar with the amps controls). That should do it. If you split them FR response will be different for each sub and calibration will be tricky.
Let us know how it sounds.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've now recently received the SVS 20-39 pc+ and have set it up properly with the RS SPL. Anyone reading this, and is thinking of matching this sub to a psw505 for dual subs....well....don't waste your time. Drop the psw505 asap and stick with svs. This is the cleanest, most powerful bass that I have ever heard. Where did all the boominess go? I'll tell you....to a buyer on e-bay!!! As most of you know, and as I've recently discovered, these subs cannot be compared fairly as they are in totally different realms of SQ. Hands down, best HT purchase to date.
Kinda thought this would be your conclusion. There's no similarity to each other's sound signature. It probably would have muddied up your room. Enjoy your sub.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
