Extracting m4p audio files....
RuSsMaN
Grabbed a few from itunes, want to burn a regular audio cd - winamp doesn't seem to want to do anything with these files.....
I just need to output them to wav and burn.
Cheers,
Russ
Cheers,
Russ
Post edited by RuSsMaN on
Aah Russs, odd to find you in this predicament of dealing with these dirty little file types.;) The Mp4s I believe are protected Apple files so most software won't (can't) touch these as they are protected Apple files.
You can probably find a freeware program that will strip the DRM from these files. The windows media version is called fairuse4WM. (Do a search) I'm sure there is an apple file version of the same program that will strip out the DRM and allow you to convert to a different file type though I'm not familiar with this software.
I've done my best to strip all drm and convert to mp3 for easier use for all 200g of my music. Good luck as generally speaking DRM is a PITA!
Be glad to help if I can do anything more. Feel free to pm me.
RichAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Ahh, I see, I bought it, but Apple still owns it.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You are correct sir. As always there are ways around they system.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Not having much luck so far, trying a conversion program now, unsuccessfully.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I'm interested in this also. Please keep us posted
Good luck & thanks in advance:) Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Ok, you waste a cd (or two, three, whatever) - but in iTunes preferences / advanced / burning, change the output to 'Audio CD'.
Create a playlist of the songs you want un-f'd, and burn an audio cd. Then rip em back (I use Winamp) to mp3, wav, whatever you want.
Round about method, but works, and no other 3rd party software needed to convert.
Cheers,
Thanks!Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
I-tunes huh? Sounds like a good thing to I-gnore.
iTunes is a pretty decent program. Just dont buy songs from iTunes music store and you are good. Almost 90% of the songs that you buy online have DRM in it, the only exception being eMusic which sells its songs DRM free.madmax wrote:I-tunes huh? Sounds like a good thing to I-gnore.
madmax-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
This process works but degrades the sound quality further as lose some detail on m4p to wav conversion and then loose some more when wav is converted back to mp3.RuSsMaN wrote:Ok, you waste a cd (or two, three, whatever) - but in iTunes preferences / advanced / burning, change the output to 'Audio CD'.
Cheers,
Russ-izafar
I'm not looking for mp3's for quality or critical listening, but they suffice for background music throughout the house and what not.
BTW, I didn't notice any degredation ripping them to an audio cd.
Cheers,
I upgraded to this last week. little did I know that ALL of the music that I purchased & downloaded over the last 2 yrs will now no longer play on my pc.:mad: Message said they wouldn't play because of a security issue & to download this fix. Nothing happened.:mad: :mad: :mad:
Fortunately I had already copied them to cd! So word to the wise either keep WM10 or copy everything over to cd's before you upgrade!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I'm running WM11. Everything is fine here.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Considering what blank CDs cost nowadays (read : nothing) I've been using RuSsMaN's method of removing DRM for a while (for the few songs I actually buy from iTMS). It beats trying to hunt down and install some pirate program.If you will it, dude, it is no dream.
I run mp3s to my Denon thru my network via WMP. Since WMP will not recognize iTunes files, I had to burn the play list as Russ described. Unfortunately, I found a big difference between a
.mp4 file ripped to .wav and then back to .mp3
and
Original CD ripped to .mp3 with LAME.
Now if I could just figure out how to play .flac files thru WMA I would be in business. As cheap as music goes on Amazon these days, I will no longer buy from iTunes.
