Cleaning gold plated terminals
Listener10
Listener10 Posts: 8
I have an older amp with gold plated input terminals.
I've had some trouble with "clear" connections, and I can see that I really need to clean the input terminals (not just wipe off the dust).
I don't want to strip away the coating though...any suggestions?
Post edited by Listener10 on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited March 2007
    Jewelry Cleaner? Maybe? I don't know. Just a thought.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • dorokusai
    dorokusai Posts: 25,631
    edited March 2007
    Just get some simple contact cleaner from Radio Shack if you need it quick, or pick up some stuff from CAIG. They make great stuff...look for the AV Survival Kit.
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited March 2007
    For something really cheap, you can use rubbing alcohol. Try to find the kind that is 90 - 91% alcohol. I've seen it in walmart along with the usual 70% stuff. I don't think that it is strong enough to strip off the plating.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • Listener10
    Listener10 Posts: 8
    edited March 2007
    Thanks. I didn't have any jewelry cleaner around, that sounded like a good idea. I did try rubbing alcohol and it seemed to work reasonably well.
    I should be good for now.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Deoxit & Deoxit Gold... great stuff.
