Cleaning gold plated terminals
Listener10
I have an older amp with gold plated input terminals.
I've had some trouble with "clear" connections, and I can see that I really need to clean the input terminals (not just wipe off the dust).
I don't want to strip away the coating though...any suggestions?
Post edited by Listener10 on
Jewelry Cleaner? Maybe? I don't know. Just a thought.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Just get some simple contact cleaner from Radio Shack if you need it quick, or pick up some stuff from CAIG. They make great stuff...look for the AV Survival Kit.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
For something really cheap, you can use rubbing alcohol. Try to find the kind that is 90 - 91% alcohol. I've seen it in walmart along with the usual 70% stuff. I don't think that it is strong enough to strip off the plating.Robert
zombie boy 2000 wrote:You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's -
Thanks. I didn't have any jewelry cleaner around, that sounded like a good idea. I did try rubbing alcohol and it seemed to work reasonably well.
I should be good for now. -
Deoxit & Deoxit Gold... great stuff.
