What level do you run your sub at?
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2007
    Holydoc wrote:
    0db for movies (i.e., calibrated with the other speakers) and not used for music since I play in "pure" two-channel mode. That is why I bought the big boy towers so that I did not need a sub for music.
    Is this direct, pure audio, or stereo mode on the receiver?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • john22614
    john22614 Posts: 214
    edited November 2007
    The sub should blend in smoothly with the music.....one way to achieve this is to sit in your favorite spot, play a song with good bass, and then tune the sub down to the pt where the deep bass is just noticeable. This will add solid low end to the music without it being boomy and will be the way it is meant to be heard. This setting should also be good for movies.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
    treitz3 Posts: 20,076
    Since the last time I posted on this thread I have learned that it doesn't matter what other folks have their setting at. It is room, speaker, reflection and setup dependent, then you have to throw in personal preference and whether you are listening to HT or music and musical genre's. ;)
  • Serendipity
    treitz3 wrote: »
    I can understand that. But I still think running your sub flat is ideal.
    VR3 Posts: 29,531
    for HT ---
    I think running a subwoofer as much as 10 db hot would not be overkill -- as long as its crossed low and isnt crowding the midrange....
    For music --- my taste have really changed - and probally like it a little less than flat...
