What level do you run your sub at?
Serendipity
Serendipity Posts: 6,975
Just wanted to know what levels most people run their sub at. Would like to see if a higher seeting is more appropriate for movies, or to keep the sub low at all times. Some say to run the sub hot for movies.
I keep my sub -3db lower than my mains, so the DVE test tone peaks at 70-72db for the sub and 75db for the mains.
So -3db for me here.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • McLoki
    McLoki Posts: 5,231
    edited February 2007
    I run about +2 or +3 over my other speakers. My remote has a sub level button on it though so I can taylor it for the movie if needed.
  • Serendipity
    Isn't that a bit loud?
  • McLoki
    McLoki Posts: 5,231
    I don't think so, but if you come over and don't like it I would be glad to turn it down until you leave... :)
    Michael
  • scottvamp
    scottvamp Posts: 3,277
    Cal. at -3. Volume at 3 to 4 o'clock. Anything else and i destroy homes and bottles fall off shelves.:eek:
  • Schwingding
    Schwingding Posts: 363
    It depends who's home! I leave it at 0db, that is - calibrated in line with the speakers, but if my wife is in the house I'll back it down to keep her happy. Raising it above calibration levels would be ridiculous with dual pb12 +/2 s.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
    VR3 Posts: 29,566
    For music, I like a tad hot - just my style of sound I like.
    Usually around 2 or 3db hot for music.
    For movies, if it were up to me Id have dual PB 12 Ultra/2 on each end of my futon and you wouldnt have a bowl movement in 2 weeks...
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Mine is +4 because I don't get to listen very loud. It seem just right to me though.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • m00npie
    m00npie Posts: 697
    0 db. If I'm home alone, I'll adjust the gain slightly higher to just less than half on the PB12\plus2 rather than adjust the receiver. I always wanted to go more but what’s the point of breaking things in the house.
  • Sherardp
    Sherardp Posts: 8,038
    I run mine at first notch on the sub itself then at -5 in the AVR and its still loud. Im still running it a little hot.
  • Shizelbs
    Shizelbs Posts: 7,433
    I'm always adjust my sub, but I have it louder than my speakers thats for sure.
  • wingnut4772
    wingnut4772 Posts: 7,519
    +2 or 3 ish
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Serendipity
    So you've lowered it eh?
    Last time I heard your SVS I could have sworn there was an earthquake going through NC.
  • jwhitakr
    jwhitakr Posts: 568
    +3 for me. I think it's entirely up to your personal preference, though.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • Huck344
    Huck344 Posts: 453
    +2 for movies, +4 for music. Though, I have to say that on certain occasions, I've gone +5 just for the fun of it!
    VR3 Posts: 29,566
    If you think that was an earthquake - hmmm, you should come back down when I get the Taylos and VMPS setup - will be absolutely sick.
  • AndyGwis
    AndyGwis Posts: 3,655
    I run my sub hot. . . so hot that Al Gore knocked on my door to yell at me for causing global warming.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
    treitz3 Posts: 20,153
    I currently have a Polk Audio PSW1000. The 0dB and +3dB button is set at 0dB's with Hz set at 52. Volume is at inbetween 10-12 out of a possible 100 [10 for music, 12 for movies] This is with a system that has an available 2500 watts of power before it's exhausted, but if I put the sub up any more than that, I can tell where it is. For me, that's a no-no. Personally, I can't stand "Boom" at the bottom, just a great blend of the frequencies required to make the whole spectrum of sound emitted from the rig a wonderful experience, and a joy to listen to.
  • Serendipity
    edited March 2007
    Sure...but next time you're in my area of residence you can check out my setup - no earthquake pounding bass but a 140" front projection screen makes up for it.
  • mjhughes
    mjhughes Posts: 14
    edited March 2007
    Rather than running the sub at a setting that others have, you should download some test tones, (try these ones http://www.hsuresearch.com.au/Setup.html) play them back through your system and measure the tones with an RS meter. Adjust the sub settings so the tones measure as even as possible on the meter. The settings in your room will be different to the settings in anyone elses room. My point is that a general setting of +3db for the subwoofer is just an arbitrary figure. For the best sound in your room, you need to find the setting for your sub in your room buy measuring and listening. The results will be far more satisfying.
  • Serendipity
    edited March 2007
    That's what I am talking about.
    I use an RS sound meter to adjust the level of the sub using test tones on an Avia or DVE disc.
    In my room the best level is achieved if the sub is set LOWER than what the test discs recommend.
  • harold280z
    harold280z Posts: 72
    edited March 2007
    I run my basement sub just a bit hot +2...seems to make the pictures on the wall shake just a bit. Bedroom sub +1 on most movies.
    Bedroom Stuff 5.1
    Pioneer Elite VSX-82TXS
    Pioneer Elite Blue Ray BDP-05FD
    Monster Power HTS3500
    Harmont Remote 880
    Sony Bravia KDL40S2400
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Martin Logan Abyss Sub:D :D ::D
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite DVD DV48AV
    Pioneer Elite 910HD
    Monster Power HTS3600
    Harmony Remote 688
    Warfedale Diamond 8.4 Front
    Warfedale Diamond 8.2 Sides & Rear
    Warfedale Diamond 8 Center
    SVS PB12-Plus/2 Sub:D:D :D
    edited March 2007
    Sorry, this is continued from Mjhughes' post I'll quote him next time......
    ....and if you don't have a remote control, see if someone else can make the adjustments while you are sittin' in yer "spot". The sound emmitted from the sub will change as you get closer, make the adjustment, and change as you get further away from the sub as well.
    If you have someone else make the adjustments, you will know how it effects the sound where YOU are sitting. (My suggestion) Play about nine or ten of the tracks that match the kind of music that you listen to, and learn "about" where you like it, so at least that way you will have a general "reference" as to the setting that you like. Good luck!
  • mjhughes
    mjhughes Posts: 14
    edited March 2007
    I too set my sub lower than the test signals on Avia or VE would suggest. I find that those levels result on very heavy bass that is out of proportion with the rest of the sound. By using test tones and a meter, the result is so much better, and you can start to understand what sound is doing in your particular room, a peak here, a dip there etc, then you can experiment with placement too to get better results. Trust your ears and change the level if it sounds wrong I reckon. A loud sub setting can sound impressive at first, but becomes annoying very quickly. I try to aim for the most accurate sound reproduction rather than a fake boomy bass sound.
  • Huck344
    Huck344 Posts: 453
    edited March 2007
    Was unable to download the tones from your link. But I did find another site that had free test tones. http://www.ronelmm.com/tones/
  • Serendipity
    edited March 2007
    Good advice.
    I tried setting my sub a bit higher so that it was in line with the speakers, and it provided good results for movies. It sounded similar to that of a high-end movie theater (AMC 25 in Times Square) with the sub set at 0db instead of at -3db. I was impressed with the results.
    For music though, I don't want to "hear" the sub, so I have it set as low as possible.
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    loud
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Face
    Face Posts: 14,340
    edited March 2007
    BIZILL wrote:
    loud
    :D
    Same here.
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2007
    i have ran mine any where from 0 to +5 and have had no problems but i uslay have it setup at 0 or +1 i thought i was going to die when i had the sub setup at+3 and above listning at a good volume but i also have 4 18's
  • Serendipity
    edited March 2007
    Tried today at +3db and the bass was overwhelming.
    Went back down to 0db for movies and -3db for music, and was much more satisfied.
  • Holydoc
    Holydoc Posts: 1,048
    edited March 2007
    0db for movies (i.e., calibrated with the other speakers) and not used for music since I play in "pure" two-channel mode. That is why I bought the big boy towers so that I did not need a sub for music.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
