SDA SRS 1.2 tl SIDE AND REAR CORNER PANEL REMOVAL?
snow
I know there is a way to safely remove the side and rear corner panels on sda srs 1.2 tls. But can anyone share this secret with me please? I dont want to get too rough and destroy something by accident.I want to remove these and clean the cloth. REGARDS SNOW
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Post edited by snow on
snow wrote:I know there is a way to safely remove the side and rear corner panels on sda srs 1.2 tls. But can anyone share this secret with me please? I dont want to get too rough and destroy something by accident.I want to remove these and clean the cloth. REGARDS SNOW
Try a PM to HTrookie or Polk65. Darqueknight may be able to help you also. Heck for that matter try F1Nut too. -
They are held on with Treeloc's and simply pop off.Political Correctness'.........defined
President of Club Polk -
Thanks guys. I will pull a little harder then
:eek:
REGARDS SNOW
Update they are off now. It cost me a little of my blood (nicked my finger during the process) Sweat and luckily no tears. I would have cried if i had broke one of them getting them off. THANKS AGAIN SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
DarqueKnight's post with pics.
http://www.polkaudio.com/forums/showthread.php?t=26036 -
Thanks polk65Polk65 wrote:DarqueKnight's post with pics.
I tried doing a search earlier but to no avail, for some reason when I type in sda srs anything I get no posts found results. I have no reason why perhaps its a glitch with the servers.
Oh well I have it bookmarked in case some poor soul like myself need to know how to remove them.
These do come off allright but its not an easy task, or at least they werent for me. they were attached pretty well lol. I was certain I was going to break one prying on it. but they really needed a cleaning and now the job is over and they look better.
THANKS TO ALL OF YOU. REGARDS SNOW Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
http://www.polkaudio.com/forums/search.php?searchid=688438Political Correctness'.........defined
TY F1nut.F1nut wrote:
regards snowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
