SDA SRS 1.2 tl SIDE AND REAR CORNER PANEL REMOVAL?
snow
snow Posts: 4,358
edited March 2007 in Vintage Speakers
I know there is a way to safely remove the side and rear corner panels on sda srs 1.2 tls. But can anyone share this secret with me please? I dont want to get too rough and destroy something by accident.I want to remove these and clean the cloth. REGARDS SNOW
Post edited by snow on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Try a PM to HTrookie or Polk65. Darqueknight may be able to help you also. Heck for that matter try F1Nut too.
    F1nut Posts: 52,244
    edited March 2007
    They are held on with Treeloc's and simply pop off.
  • snow
    snow Posts: 4,358
    edited March 2007
    Thanks guys. I will pull a little harder then :D :eek: :D REGARDS SNOW
    Update they are off now. It cost me a little of my blood (nicked my finger during the process) Sweat and luckily no tears. I would have cried if i had broke one of them getting them off. THANKS AGAIN SNOW
  • Polk65
    Polk65 Posts: 1,405
    edited March 2007
  • snow
    snow Posts: 4,358
    edited March 2007
    Polk65 wrote:
    Thanks polk65
    I tried doing a search earlier but to no avail, for some reason when I type in sda srs anything I get no posts found results. I have no reason why perhaps its a glitch with the servers.
    Oh well I have it bookmarked in case some poor soul like myself need to know how to remove them.
    These do come off allright but its not an easy task, or at least they werent for me. they were attached pretty well lol. I was certain I was going to break one prying on it. but they really needed a cleaning and now the job is over and they look better. :) THANKS TO ALL OF YOU. REGARDS SNOW
    F1nut Posts: 52,244
    edited March 2007
    http://www.polkaudio.com/forums/search.php?searchid=688438
  • snow
    snow Posts: 4,358
    edited March 2007
