Should I run my amp thru the carwash?
soiset
soiset Posts: 724
edited March 2007 in DIY, Mods & Tweaks
I just got a Rane MA-6, a six channel pro amp that weighs about 8,000 lbs. It was in a bar for I guess most of its life. The seller had removed the filter from the fan and said it just fell apart.
I plugged it in, the fan came on, and jeezuss, what a stench. What is the best way to clean this Philips Morris special? It's probably got nicotine gummed up all over the innards. I'd like to just dip it in a barrel of DeOxit.
Also, where can you get new filter material?
Post edited by soiset on
  • Systems
    Systems Posts: 14,872
    edited March 2007
    Methyl hydrate might do the trick.It is great for removing built up gummy substances.
    Testing
    Testing
    Testing
  • soiset
    soiset Posts: 724
    edited March 2007
    Does that come in a can? Do you just soak it in that stuff and then let it run off? Does it eat insulation?
  • Systems
    edited March 2007
    It comes in plastic bottles.
    It is electronically safe.
    Pore it on to a cloth then wipe.
    Testing
    Testing
    Testing
  • soiset
    soiset Posts: 724
    edited March 2007
    Can I just fill a bucket and dip?
    Just kidding. Thanks for the info, I'm googling now.
  • Face
    Face Posts: 14,340
    edited March 2007
    Electrical contact cleaner?
