Should I run my amp thru the carwash?
soiset
I just got a Rane MA-6, a six channel pro amp that weighs about 8,000 lbs. It was in a bar for I guess most of its life. The seller had removed the filter from the fan and said it just fell apart.
I plugged it in, the fan came on, and jeezuss, what a stench. What is the best way to clean this Philips Morris special? It's probably got nicotine gummed up all over the innards. I'd like to just dip it in a barrel of DeOxit.
Also, where can you get new filter material?
Post edited by soiset on
Methyl hydrate might do the trick.It is great for removing built up gummy substances.Testing
Testing
Testing -
Does that come in a can? Do you just soak it in that stuff and then let it run off? Does it eat insulation?
It comes in plastic bottles.
It is electronically safe.
Pore it on to a cloth then wipe.Testing
Testing
Testing -
Can I just fill a bucket and dip?
Just kidding. Thanks for the info, I'm googling now. -
Electrical contact cleaner?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
