Silent Speakers
VR3
Thats possibly the craziest thing Ive ever heard.
I love it.
I love it.
Post edited by VR3 on
You're a classic case of the "think too much" crowd. No offense, but relax and unless it's actually audible, don't worry about it.
I have a small fridge, wired in series, with my 2CH rig and haven't heard a peep.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I try to maintain a constant flow of beer out of the fridge; that seems to help not listening to any noise._________________________________________________
Hey Sona --
That's a great idea. I also turn off my heat or AC before listening to music. It is foolish to buy all of this expensive audio gear and screw up your listening pleasure by tolerating a noisy environment.
Keep on doing what you do...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Nope I figure at the decibel level I listen to, I cant hear anything but music anyways. If you can hear the fridge when your listening to music then either the music is way to low or you have one helluva noisy fridgeSona wrote:Just curious, particularly for those of you who have attained the goal of eradicating white noise and equipment hum, have you also created a silent listening space? (Sound proofed walls, radiant heat vs. forced air, ultra quiet appliances, etc.?)
When I was listening critically to the RTi8’s I test drove, I turned off the heat, tripped the circuit breaker to silence the fridge, and unplugged other humming electronics. Best I could manage at the time, but it’s certainly not a livable option!
Sona
:eek:
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Plus if you are a believer in power conditioning I believe it would help in this aspect to. Turning of appliances like a fridge or ac will draw less power overall (not much of a difference) but will also eliminate any junk added to the line from compressors cycling.
I turn the ac off when listening for three reasons. First it is audible as I don't listen to music very loud. Second the unit is outside of my room, so I can hear it running. Third when it kicks on and off the lights dim and the music gets quieter and compressed for a sec or so.
Jared -
There are many jazz and classical music tunes that have such a wide dynamic range that can sound better with a low noise background. When I remodeled by listening room in the 80s I put in new windows to reduce the road noise. I can also here the furnace coming on and off. Yet I can hear no improvemnet or difference with expensive cables or line cords.
The total listening enviroment is a very important factor to the listening experience in my experience. -
Background Sound Enviroment in cars for example sucks. I couldn't really listen to any music that had a large dynamic range in the car. I gave up on quality car audio in the 80s because of the background noise.
Maybe I should get a quieter car. -
I too think the room environment plays a great role in sound quality. When I listen, I turn off the A/C or heat, because either seems to cause noise in my system (especially the A/C).
The A/C unit is on a dedicated circuit and my system is on its own dedicated circuit too, but somehow the cycling of the compressor causes my system to have more background noise.
I have tried power conditioners which have helped, but did not eliminate the problem. The best solution was to just turn off the A/C.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
dorokusai wrote:I have a small fridge, wired in series, with my 2CH rig and haven't heard a peep.
Mark- You really ought to add power conditioning to this set up though. The ice will form much faster, will have better crystaline structure and will also last much longer in your Jack Daniels.:rolleyes: -
I shut off the AC sometimes because I can hear it blowing. I also turn off any dimmer controls just in case there is something there that would annoy me. (even though I don't hear anything). I don't turn off the fridge any more since forgetting about it once.
snow wrote:Nope I figure at the decibel level I listen to, I cant hear anything but music anyways. If you can hear the fridge when your listening to music then either the music is way to low or you have one helluva noisy fridge
:eek:
REGARDS SNOW
LOL...I'm with you buddy...sometimes its hard to hear myself think..much less the fridge...:D
The decibles I acheive to get over the wife and kids are really remarkable.l:eek:Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
The battery chagers for you drill are very noisy. They can make a buzz every 2 seconds.
capecodder wrote:Mark- You really ought to add power conditioning to this set up though. The ice will form much faster, will have better crystaline structure and will also last much longer in your Jack Daniels.:rolleyes:
I have all my hardcore power conditioning gear ON the fridge! No need to waste that stuff on audio gear
Ice never looked or tasted better. CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
dorokusai wrote:Ice never looked or tasted better.
Was this determined after a grueling series of double-blind tests? Do you have graphs and/or charts or am I supposed to take your word for it?:DI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Agreed and your are as anal as I am, it looks like.:eek: My next step will be to go to XLR cables because from what I have heard from some highly respected and knowledgable folk, the extra ground wire is isolated from the negative path, cancelling out the interference noise. I have tried a Richard Grey RGPC 400 Pro with better results as to the system shutting the [censored] up, but still I have "that noise". [not to mention better sound] All of my low power and digital components are plugged into a Monster Power HTS 1600, and then plugged into the RG 400 pro, then into the outlet.Sona wrote:When I was listening critically to the RTi8’s I test drove, I turned off the heat, tripped the circuit breaker to silence the fridge, and unplugged other humming electronics. Best I could manage at the time, but it’s certainly not a livable option!
You would think I would have enough protection. Nope.
I have tried what you have done and even gotten more anal when I tapped a empty neighbors house with no appliances installed whatsoever, and the noise was still present. This has been a quest of mine for some time, and I keep losing. However I will not quit. One day, man.......one day.
My biggest problem is dirty power installed by crappola electricians who don't care to come back to correct the problem [buttmunches] and not having a dedicated 20 amp line set up just for the rig. I wish you luck in your quest!
I hope this helps.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
dorokusai wrote:You're a classic case of the "think too much" crowd. No offense, but relax and unless it's actually audible, don't worry about it.
Yeah but you have Maye brass points coupling it to the slab.:rolleyes:I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
HTrookie wrote:I try to maintain a constant flow of beer out of the fridge; that seems to help not listening to any noise.
I think you and I would get along swimmingly:DI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Yep an almost ideal lisening space. Absolutely silent room. If the system is on I can really turn up a quietpassage of music and just faintly hear amp hiss with my ear directly near tweeter.The room can be sealed off from the home. I listen often at very low levels.
You bring up some valid points. I have a house with a great room that consist of the livingroom/dining room/kitchen all in a single shared space. My biggest demon is the damn dishwasher!! LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
There are a number of companies that offer power conditioners at reasonable prices. Right now I'm checking out the PS Audio Noise Harvester, but over time I'm going to try and check out as many different possibilities as I can.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
