system messed up
bolelet1
I had some guests over the weekend and somehow I believed someone messed up my Yamaha settings. I can't remember what frequency it should be but now I see it is at 120kz and everything (L/C/R and surround) is Large. I know the front should be set to small but I'm not sure about the center and surround (I have 5.1 instead of 7.1). Futhermore, it looks like there is no sound coming from my surround speakers. Please help me figure this out. Thank you.
My system:
Yamaha RXV1400
B&K 3140 (Powering the front and center)
Onkyo 282 (Powering the surround)
RTi10
CSi5
FXi5
My system:
Yamaha RXV1400
RTi10
CSi5
FXi5
Post edited by bolelet1 on
I would try to run the Yamaha YPAO auto-calibration built into the receiver to get approximate settings for your speakers, and then use an SPL meter for the fine tuning.
I'm sure nothing is actually "messed up," probably just your crossover settings and speaker settings were changed.
The Yamaha YPAO calibration should set the speakers at 80Hz as a starting point for crossover, and then "Small" for all your speakers. If not, try those settings out and see if they work.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Make sure you never invite those particular guests over ever again!:mad:bolelet1 wrote:I had some guests over the weekend and somehow I believed someone messed up my Yamaha settings. I can't remember what frequency it should be but now I see it is at 120kz and everything (L/C/R and surround) is Large. I know the front should be set to small but I'm not sure about the center and surround (I have 5.1 instead of 7.1). Futhermore, it looks like there is no sound coming from my surround speakers. Please help me figure this out. Thank you.
My system:
Yamaha RXV1400
RTi10
CSi5
FXi5Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Will do and for sure no more guests in the meantime. lol. What I am worried about is that no sound seems to come out from the surround speakers. I will try the YPAO and see what happens Thanks.
