Hhheeelllppp!!!
  • faster100
    faster100 Posts: 6,124
    edited December 2002
    depends if you believe in sharing software i will send you a copy, or e-bay will have some.... do you have a copy of that XP?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • faster100
    saving pictures with aol is a problem if you use there browser, open a internet explorer window and use that to surf e-bay and what not and then try and save the pictures, AOl kinda stinks for alot of reasons, I use broadband now but have used so many dial ups its crazy
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    F1nut Posts: 51,672
    faster,
    I don't have a copy, can I make one? Where I live I have no choice but to use dial up. They tell me that in 6 to 8 months I can get DSL.
  • faster100
    Actually XP is tricky to copy(burn) and if you don't have the original xp disk its basically impossible, i'f you need a "copy burned) of windows 98 let me know... But don't just change from xp back to 98 for the picture problems, unless xp just isnt working good for ya
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    F1nut Posts: 51,672
    faster,
    Ok, I'll take your word for it and your advice about changing just for the photo snafu, everything else seems ok. Thanks for all your help.
    F1nut
  • faster100
    No prob
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Zen Dragon
    Zen Dragon Posts: 501
    edited January 2003
    Gidrah:
    The ironic part is that I spend quite a bit of time on the computer and just recently figured out how to get the "Originally posted by ..." going,
    Ok Gidrah, show off your knowledge, how do you get that "originally posted by"
    As you can see from above I have know idea. :rolleyes:
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
    F1nut Posts: 51,672
    edited January 2003
    Originally posted by Zen Dragon
    After you click on quote (at the bottom right) it will come up between the italics. Don't delete it and it will show up. You can check what you've got by clicking Preview Reply.
  • faster100
    edited January 2003
    pretty cool, i just learned this as well after your post, : 0
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    F1nut Posts: 51,672
    edited January 2003
    Always glad to help :D
  • faster100
    edited January 2003
    Thanks,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Zen Dragon
    edited January 2003
    Wow, pretty cool, and than you just delete the part you are not referring to?
    I was hitting reply at the bottom, then quote, which gave me empty italics, then copy pasting from the quote I wanted between the italics. This worked for the quote, but didn't include the "originally posted by.
    Thanx :cool:
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    F1nut Posts: 51,672
    edited January 2003
    Yes! :cool:
