Question about speaker cable
ray2per
ray2per Posts: 15
Is it okey to connect one end of speaker cable by crimping both ends of wire? Does it affect the quality of speaker or degrade the sound? Or is it worth to buy a long one instead of attaching both ends?
Post edited by ray2per on
  • steveinaz
    steveinaz Posts: 19,545
    edited February 2007
    The way I understand it, your cable is too short so you want to crimp a length of cable to reach?
    It's not the best approach, but it will work. You'd be better served to get a set of speaker cables that are the length you need.
  • beardog03
    beardog03 Posts: 5,550
    I agree...
    It will work , but I would go with longer cables..
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Burnzy
    Burnzy Posts: 250
    beardog03 wrote:
    I agree...
    Ditto...
    Always best to go w/one length of cable rather than trying to put two together.
    SYSTEM
    HDTV ..........Sony KP-57WV600
    CD / DVD......Sony DVP-C675D
    AVR ............Denon 2801
    MAINS .........Polk RTi8
    CENTER .......Polk CSi5
    Surrounds ....Polk FXi3
    Sub ............Polk PSW-250
    Cables.........Zebra Cables
  • ray2per
    ray2per Posts: 15
    Thanks for all your input. I bought monster cable from compusa that went closed in our area for a really cheap prize. I will going to order a new cable from blue jeans. I read a lot of good reviews about that company. Should I change my whole speaker wire because I have a different brand? O should I just change the one that I crimp?
  • WilliamM2
    WilliamM2 Posts: 4,807
    Don't waste your money, just solder on the length you need. You can even mix brands.
    There is nothing magic about speaker wire.
  • steveinaz
    ...or better yet, just use metal bread ties...:rolleyes:
  • ben62670
    ben62670 Posts: 15,969
    Not knowing what he has for a system this could be bad advice. I would not recommend splicing speaker wire. It looks half assed, gives an opportunity for shorts(watch out for any sharp bumps the solder may create), and if you have a decent HI-FI system speaker wire definitely can may a big difference in sound. I didn't use to believe in wires making any difference, but it sure can with many systems.
    Ben
    Ben
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Hell.... I don't use anything at all. I just stare at the speakers and imagine the sweet, sweet music they must make.
    Actually, I think it's the fridge I've been staring at.
  • WilliamM2
    Shorts? Only if you don't insulate the wires.
    And I have a decent sound sysytem, with over $10,000 invested in it, but try as I might, I hear no difference in wires. And from the data collected over the years, neither does anyone else.
  • zombie boy 2000
    The Amazing Kreskin sees all...
    And how is it that you know what I hear? What tests have you run to determine if you, indeed, have direct access to my sensory perceptions? Double-blind, multiple choice, essay?
  • WilliamM2
    There are thousands of "Golden Ears" who claim to be able to hear the difference, yet there is not one case where any have been able to prove it in any sort of blind test. Why is that?
    Maybe you could be the first, but I doubt it.
  • zombie boy 2000
    I never said I could... did I?
    You just made a mind-boggingly broad statement by proclaiming "neither does anyone else"
  • WilliamM2
    I can only go by the evidence presented so far.
    I have a hard time with claims that have no basis in science or reality.
  • ray2per
    ray2per Posts: 15
    Thanks for all your reply. That was pretty good response.
    Now I think maybe I should stay with my current speaker wire
    and not buy the blue jeans cable. By the way I have RTi 12, fxi5, Infinity sub that I'm planning to upgrade in the future and LSi C that I am going to sell and get the CSi5.
  • steveinaz
    If you want an inexpensive, yet good fix...get some Radio Shack solid copper 18awg. It got a nod from Stereophile as "pretty darn good cable in a pinch." For a $6 roll of wire, that's not bad press...
  • WilliamM2
    18 guage for a longer run? That makes sense...
  • bsoko2
    bsoko2 Posts: 1,449
    Try Home Depot. They carry a brand made by GE and it is 14ga and claims to be made for HDTV digital. + is copper strands and - is plain silver colored wire. I have been using it on my system for several months now with no issues. My rear surround runs are more than 60 feet (up and over thru the ceiling).
  • louthewiz
    louthewiz Posts: 581
    I am an avid fan of home theater and music and I know that speaker wire is wire and many buy those overpriced speaker cables when they all do the same thing they conduct electricity.
    Read this :
    http://www.roger-russell.com/wire/wire.htm#wiretable
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Kimber Monocle, period.
  • ben62670
    Please let us know what type of system you have so we can give proper advice.
    Ben
    Ben
  • louthewiz
    "Kimber Monocle"
    :rolleyes: Why would I buy that over priced junk when I can make my own for much less.:rolleyes:
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • beardog03
    MIT..
    nuff said..!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • ray2per
    ray2per Posts: 15
    Ben
    I have pair of RTi 12, pair of FXi5, Infinity Sub, and LSiC. I got this all for $1500.
    I have a sony str da 333es as pre out. I'm planning to get an amplifier, a subwoofer maybe svs or outlaw and I'm going to get CSi5 and sell the LSiC.
  • hearingimpared
    hearingimpared Posts: 21,136
    HERE WE GO AGAIN!!! LOL I can't wait to see this one develop.
    F1nut Posts: 51,751
    Goodness me, it's a gaggle of Anti Audio HiFi Insurgents.
  • hearingimpared
    You crack me up. . . gaggle!
    F1nut Posts: 51,751
    Thanks, I'm here everyday. :p
    F1nut Posts: 51,751
    Sorry for the hijack Ray. Steve gave you good advice and you could do far worse than to follow it.
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    OH NO!!!! Here we go again. I feel another "wire debate" developing here . . . :p
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • Deadof_knight
    Deadof_knight Posts: 980
    My wife and kids arent into audio like I am and they heard the difference between 16ga and 10ga ,they ask me if I changed something because it sounds different thats about as blind a test as there is .
    IMHO yes the spliced wire (ie crimp or solder)will work when done correctly will work for a long time and be inexpensive but he ask for our advise.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
