rti 8 or monitor 70
carmos
carmos Posts: 11
edited February 2007 in Speakers
hi all, i have had my monitor 50's for about 2 months now ..they are ok but i need a fuller sounding speaker.in the midbass and lower area...should i stick with the 70's and match the speakers i already have . or are the rti 8 that much better for music and movies..also will the rti 8 timbre match with the monitor series..i do about 65% movies 35% movies .thank for any help.
polk audio
front-monitor 50
surrounds-monitor 50
back surrounds monitor 30
center cs2
sub-psw12
avr denon 987 aka 2807
dvd 757 aka 1930 ci
plasma hp 5060 50"
remote harmony 880
wires monster and jean
Post edited by carmos on
  • Willow
    Willow Posts: 11,218
    I think your issue might be that you're not feeding them enough power, the M70s have lots of drivers to push and I'm affraid your receiver isn't giving it what it needs. It could also be a xover issue. what do you have your system xover at ?
  • carmos
    carmos Posts: 11
    hi willow, i have my monitor 50's x-over at 60 hrtz.. the denon is 110 watts per. channel x 7...into 2 channels one of the reviews has it pushing about 140 watts.. so for the monitor 50's that should be plenty of power...i am hoping that the 6 1/2 drivers in the 70's or the rti 8 would give me a deeper sound.e.g. from 100 hrtz and below... of those 2 speakers for the same money which do u think is better the 70's or the rti 8 .thanks for ur help
    polk audio
    front-monitor 50
    center cs2
    sub-psw12
    dvd 757 aka 1930 ci
    plasma hp 5060 50"
    remote harmony 880
  • tommyboy
    tommyboy Posts: 1,414
    don't get the rti8s unless you decide to upgrade all of your speaks.
    If I were you, I would wait and save up money to make a worthy upgrade(better than m70s and rti8s)...
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • Ern Dog
    Ern Dog Posts: 2,237
    I've had monitor 70's before and found them to be too muddy in the lower end and they lacked detail and clarity. The Rti series is much more clear and detailed and are a big improvement over the monitor series in my opinion. If you want to upgrade from the monitor 50's to a better speaker then I would recommend moving into the Rti series. If your are going for 2-channel music w/out a sub then go with the Rti10 or 12's. If you use a good sub then the Rti8's will do the job. I found the 8's by themselves were too thin in the bass, but excellent in mids and highs. Also consider upgrading your sub if you want a better bass response.
    If you decide to transition to the Rti series I'd start by selling both sets of the monitor 50's and purchase new/used Rti fronts, then center, then surrounds, then back surrounds. In that order. If money is an issue then you don't need to do it all at once.
  • Willow
    Ok then bump up your xover to say 80, let the sub do some work on the lows at it should and was designed to , this will not only clear up your mids on your M70 but will give a bit more breathing room to your receiver.(you do have a sub...right?)
    I have 2 200w monoblocks driving each of my 8s and x over @ 60.My sub is 150w. So even though I have more power to my mains, I give a little here take a little there to even it all out. I prefer the sound of mine xover @60 then @ 80. MHO
  • AndyGwis
    AndyGwis Posts: 3,655
    Willow, he doesn't have m70's, he has m50's and is asking if he should upgrade to m70's.
    I have Monitor 60's and actually like them quite a bit. Off my fairly beefy AVR 635, they sound good. Off a solid power amp, they sound real good.
    If you eventually get better speakers (RTis), or you will probably want a better receiver and/or a separate amp to power them. Do you have preouts? Wouldn't hurt to get a cheap stereo power amp to see if it opens up the m50s. Plus, use amps can generally be sold for what you bought them, so no harm trying it out.
    Adding amps to my set-up was very fun and a great learning experience to boot. If you have some funds, try out an amp.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • carmos
    carmos Posts: 11
    thanks to all for your input...i think i will wait a bit a save some money ..then see what is avalible..i think polk is releasing a new rti series ,i saw that somewere ,will wait for some feedback on those e.g. reviews buy customers and magazines.then make a choice..thanks again! :)
    polk audio
    front-monitor 50
    center cs2
    sub-psw12
    dvd 757 aka 1930 ci
    plasma hp 5060 50"
    remote harmony 880
  • Willow
    My bad, you're right I saw that but for some reason kept thinking 70s
  • FicmanS
    FicmanS Posts: 134
    I love my 70's no complaints on them at all, they are pretty good middle ground for movies and audio... Good solid performance on Video, outstanding on audio...
    Rockin' In My House :D
    Pioneer 50 inch Plasma TV
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
    Sirius Satellite Radio, Monster 3500MKII
  • Willow
    FicmanS wrote:
    I Good solid performance on Video, outstanding on audio.../QUOTE]
    Your speakers play video ?;)
  • FicmanS
    FicmanS Posts: 134
    They sound good when used with video playback... Sadly I have to explain that..
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
  • josh_parsons626
    josh_parsons626 Posts: 219
    Well I've heard Monitor 70's before but they were used on an Onkyo receiver which IMO says it all. Needlesstosay I didn't really get the full effect of the speaker, but I didn't think it sounded all that great. But then again I have the Monitor series so I already know I don't like them!
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • Willow
    Easy cowboy...if you took the time to notice the wink face, I knew what you meant just playin with what you said..... it's sad that I have to explain myself...
