"Y" subwoofer cable suggestions
mark090852
mark090852 Posts: 999
I want to hook up my SVS and Polk subwoofers to a single sub preout on the AVR. I haven't been able to find any "Y" cable splitters that were more than a foot long....about 6" after the split. The subs will be about two feet apart so I need more length. I've looked at Monoprice and BlueJean cables websites but couldn't find what I was looking for. Can anyone suggest an online site that might have something that would work? Thanks in advance for any info.
Mark
McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Post edited by mark090852 on
  • dorokusai
    dorokusai Posts: 25,576
    edited February 2007
    Signal Cable can custom make any length & termination you want, as it's by the foot.
    I thought Blue Jeans did the same thing, perhaps you should email them and ask. You could even go DIY if you feel froggy.
  • Holydoc
    Holydoc Posts: 1,048
    Mark,
    Why not plug the "Y" into the AVR sub preout and run a cable from each branch of the "Y" to your subs? That way you can place them 2 feet or 20 feet apart.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Serendipity
    Serendipity Posts: 6,975
    You can split the "Y" in between a cable and then run the desired lengths to the subs. Although you might have to make a DIY cable.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Pepi28
    Pepi28 Posts: 248
    I second the holy man. Nice and simple.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • mark090852
    Holydoc wrote:
    Mark,
    I thought about doing that, but I have the 35 foot subwoofer cable hidden in a cable "track" that is attached to the baseboard. Also in the track are the speaker wires for the surround speakers. There is no more room for another cable. I have to keep my wife happy and the only acceptable location for the two subs is in the rear of the room behind the loveseat.
    I'm going to look at some of the other options suggested here...I'm sure there's a way to do it. I'm new to this...just a little slow to figure out all my options.
    Thanks so much, everybody, for the suggestions. I'll "get'r done"!
