IS THERE ANY MOUNT THAT IS COMPATIBLE WITH FXi3?
joeynheather
joeynheather Posts: 3
please help me!!! this is the first home theater I've ever put together and all I got left to figure out in this 2-month MISSION is which mount to choose, its been the hardest element. I just need to know what mounts are compatible with the dual keyhole mount on the back of FXi3's. I CAN'T GET NO SLEEP! PLEASE HELP!!:eek:
Post edited by joeynheather on
    tonyb Posts: 33,069
    edited February 2007
    You should really talk to Heather about that.{ Kidding..kidding}
    Maybe someone else will chime in here,have little use for mounts.
  • louthewiz
    louthewiz Posts: 581
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • brittmer
    brittmer Posts: 11
    I have the FXi5's and I just used the template that comes with the speakers to mark my holes in the drywall and installed inserts for the screws. I tried to get one of the screws into a stud. They haven't moved yet and they have been up for 8 months!!
    Bruce
  • dorokusai
    dorokusai Posts: 25,576
    I agree, a screw or rated drywall anchor works fine.
  • Demiurge
    Demiurge Posts: 10,874
    I agree with the above, but if that doesn't work, there's always Mount Hood. :p
  • MattN03
    MattN03 Posts: 558
    I mounted my FXi5's into studs w/o any issues. The included template works well.
  • joeynheather
    Well these are going to have to go into the ceiling, and its a slanted ceiling making them face right at me which is sweet if I could just get a bracket like the VANTAGE POINT BKSP, then it would be perfect. But are these mounts compatible with the keyholes or do you have to screw into them, because I'm not about to screw into my brand new speakers. I cannot find a forum, review, seller, or any other website that elaborates on this situation I'm having on trying to find the right mount. Will the BKSP work? Thanks for all your replies.
  • dorokusai
    I don't recall a bracket for that application that didn't require holes to be drilled. Is it angled so much that the dual keyhole bracket(2 Screws) won't keep it on the wall? Where do live, in a cave?
