Center Channel set up question
flr057
This may be a dumb question but.........
Could I take two RT 35's, split the signal (or wires) and use the two as a good center channel speaker(s)?
Yamaha RX-V995
HK PA 5800
Klipsch KLF-10 (front)
Klipsch Academy (center)
Polk Rt- (rears)
SVS - PC12- NSD
HK PA 5800
Polk Rt- (rears)
SVS - PC12- NSD
Post edited by flr057 on
Maybe. You would have to wire the speakers either in series or in parallel. In series, the positive wire coming off your receiver or amp goes to the postive (red) binding post of speaker #1. The wire coming off the negative (black) binding post of speaker #1 goes to the postive post of speaker #2, and the wire coming off the negative post of speaker #2 goes back to the negative terminal of your amp or receiver. When wired in parallel, 2 sets of wires come off the postive and negative terminals of your center channel amp and each wire from the positive terminal of the amp goes to each positive post on your speaker pair, the wires coming off the negative terminal of your amp go to the negative posts on your speakers.
Problem is, if wired in series you double the nominal impedance of the load on your center channel amp. Resistance therefore goes from 8 ohms to 16 ohms. That won't hurt your amp, but it might reduce the volume of your center channel speakers to the extent that they might be difficult to balance with your mains. If you wire in parallel, you reduce the impedance load on your center channel amp to 4 ohms. If your center channel amp is not capable of handling a 4 ohm load, you could fry it, or cause it to go into protection mode.
I use two speakers for the center channel, LSi9s, but they are driven by separate amps. They are 4 ohm nominal speakers. If wired in parallel the impedance load on a single amp would be only 2 ohms, which most amps and virtually all receivers can't handle well -
You can, however I'd be more worried about comb filtering when using 2 center channels at once.-Eric
-Polk Audio -
Thats a totally insane idea but it may just work...................;)
Can you explain what you mean by comb filtering?Yamaha RX-V995
HK PA 5800
Polk Rt- (rears)
SVS - PC12- NSD -
flr057 wrote:This may be a dumb question but.........
Yeah, I use a pair of bookshelf speakers. Works great.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
