Center Channel set up question
flr057
flr057 Posts: 20
This may be a dumb question but.........
Could I take two RT 35's, split the signal (or wires) and use the two as a good center channel speaker(s)?
Yamaha RX-V995
HK PA 5800
Klipsch KLF-10 (front)
Klipsch Academy (center)
Polk Rt- (rears)
SVS - PC12- NSD
Post edited by flr057 on
  • pblanc
    pblanc Posts: 261
    edited February 2007
    Maybe. You would have to wire the speakers either in series or in parallel. In series, the positive wire coming off your receiver or amp goes to the postive (red) binding post of speaker #1. The wire coming off the negative (black) binding post of speaker #1 goes to the postive post of speaker #2, and the wire coming off the negative post of speaker #2 goes back to the negative terminal of your amp or receiver. When wired in parallel, 2 sets of wires come off the postive and negative terminals of your center channel amp and each wire from the positive terminal of the amp goes to each positive post on your speaker pair, the wires coming off the negative terminal of your amp go to the negative posts on your speakers.
    Problem is, if wired in series you double the nominal impedance of the load on your center channel amp. Resistance therefore goes from 8 ohms to 16 ohms. That won't hurt your amp, but it might reduce the volume of your center channel speakers to the extent that they might be difficult to balance with your mains. If you wire in parallel, you reduce the impedance load on your center channel amp to 4 ohms. If your center channel amp is not capable of handling a 4 ohm load, you could fry it, or cause it to go into protection mode.
    I use two speakers for the center channel, LSi9s, but they are driven by separate amps. They are 4 ohm nominal speakers. If wired in parallel the impedance load on a single amp would be only 2 ohms, which most amps and virtually all receivers can't handle well
  • Eric W
    Eric W Posts: 556
    You can, however I'd be more worried about comb filtering when using 2 center channels at once.
    -Eric
    -Polk Audio
  • scottvamp
    scottvamp Posts: 3,277
    Thats a totally insane idea but it may just work...................;)
  • flr057
    flr057 Posts: 20
    Can you explain what you mean by comb filtering?
    Yamaha RX-V995
    HK PA 5800
    Polk Rt- (rears)
    SVS - PC12- NSD
  • Willow
    Willow Posts: 11,325
  • Early B.
    Early B. Posts: 7,900
    Yeah, I use a pair of bookshelf speakers. Works great.
    "God grooves with tubes."
  • louthewiz
    louthewiz Posts: 581
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
