My CS245i fried my amp
louthewiz
:mad: I was watching MI 3 this evening and when the bridge scene was on I heard a buzz then smoke and my center channel amp got fried,
Boy was I pissed and I checked the fuse which was burned and I opened the amp up and the heat sink smelled burnt and the caps right next to it ,
so my question is what could have fried and how much do you guys think it will cost?:eek:
It is an audiosource amp 100 bridged to 160 watts which really never even got warm for the past 2 years I have owned it and now poof.:(
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Post edited by louthewiz on
So many views and no feedback???:mad:My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
is the speak okay ?
how old is the amp ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
[PHP]is the speaker okay ?
[/PHP]
Yes it is
[PHP]how old is the amp ?[/PHP]
around 2 years old
[PHP]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
[/PHP]
Well I guess I am one of the lucky ones to have a friend who repairs my stuff for me and is only charging me $50.00 to fix it.:DMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Yes it is
around 2 years oldhow old is the ampPerhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.Well I guess I am one of the lucky ones to have a friend who repairs my stuff for me and is only charging me $50.00 to fix it.:DMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Yes it is
[/QUOTE]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Is it possible that the speaker cables were touching? (i.e. even a few of the positive strands were wandering over to visit with the negative terminal (or vice versa) That would create a 0 ohm load (or there abouts) and could easily fry a bridged amp.
Other than that - just unlucky timing. (didn't spill anything into it did you??)
Michael
(anyway - sorry to hear about the amp, but glad to hear about the relatively inexpensive fix)Mains.............Polk LSi15 (Cherry)
I use heavy duty banana plugs and none of the strands were touching ,and as for spilling anything on the amp it was sitting on top of an A/V rack and I have no kids in my home.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Sorry to hear what happened to your amp Lou.
I would also guess that it happened because it was bridged. From what I hear it is not a very nice thing to do to an amp even though they say it can be done.
I would take the opportunity to simply get a more powerful amp and wire it straight.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Amp repair update,
my buddy rplaced the outputs and the caps and after a while of testing it blew out again. (good thing there was no charge)
I think I'm just going to just save my pennies and buy a used amp or try to find one on the bay since I still have $105.00 left over in my paypal account from a gift certificate.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
was it two channel or a mono- if you want bang for the buck, cheap in price and quality try outlaw, adcom, something similar.Shoot the jumper.....................BALLIN.............!!!!!
If the speaker is OK, then it probably isn't the output transistors, but it is still a good place to work back from. I'd check em anyway if you smelled something on the heatsink.-Ignorance is strength -
