My CS245i fried my amp
louthewiz
louthewiz Posts: 581
edited February 2007 in Electronics
:mad: I was watching MI 3 this evening and when the bridge scene was on I heard a buzz then smoke and my center channel amp got fried,
Boy was I pissed and I checked the fuse which was burned and I opened the amp up and the heat sink smelled burnt and the caps right next to it ,
so my question is what could have fried and how much do you guys think it will cost?:eek:
It is an audiosource amp 100 bridged to 160 watts which really never even got warm for the past 2 years I have owned it and now poof.:(
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
Post edited by louthewiz on
  • louthewiz
    So many views and no feedback???:mad:
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • beardog03
    beardog03 Posts: 5,550
    is the speak okay ?
    how old is the amp ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    heiney9 Posts: 25,445
    Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
  • louthewiz
    [PHP]is the speaker okay ?
    [/PHP]
    Yes it is
    [PHP]how old is the amp ?[/PHP]
    around 2 years old
    [PHP]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
    [/PHP]
    Well I guess I am one of the lucky ones to have a friend who repairs my stuff for me and is only charging me $50.00 to fix it.:D
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • louthewiz
    Yes it is
    how old is the amp
    around 2 years old
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • louthewiz
    Yes it is
    how old is the amp
    around 2 years old
    [/QUOTE]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • McLoki
    McLoki Posts: 5,231
    Is it possible that the speaker cables were touching? (i.e. even a few of the positive strands were wandering over to visit with the negative terminal (or vice versa) That would create a 0 ohm load (or there abouts) and could easily fry a bridged amp.
    Other than that - just unlucky timing. (didn't spill anything into it did you??)
    Michael
    (anyway - sorry to hear about the amp, but glad to hear about the relatively inexpensive fix)
  • louthewiz
    I use heavy duty banana plugs and none of the strands were touching ,and as for spilling anything on the amp it was sitting on top of an A/V rack and I have no kids in my home.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • cfrizz
    cfrizz Posts: 13,415
    Sorry to hear what happened to your amp Lou.
    I would also guess that it happened because it was bridged. From what I hear it is not a very nice thing to do to an amp even though they say it can be done.
    I would take the opportunity to simply get a more powerful amp and wire it straight.
  • louthewiz
    Amp repair update,
    my buddy rplaced the outputs and the caps and after a while of testing it blew out again. (good thing there was no charge)
    I think I'm just going to just save my pennies and buy a used amp or try to find one on the bay since I still have $105.00 left over in my paypal account from a gift certificate.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • Sherardp
    Sherardp Posts: 8,038
    was it two channel or a mono- if you want bang for the buck, cheap in price and quality try outlaw, adcom, something similar.
  • SKsolutions
    SKsolutions Posts: 1,820
    If the speaker is OK, then it probably isn't the output transistors, but it is still a good place to work back from. I'd check em anyway if you smelled something on the heatsink.
    -Ignorance is strength -
