My CS245i fried my amp
edited February 2007 in Electronics
:mad: I was watching MI 3 this evening and when the bridge scene was on I heard a buzz then smoke and my center channel amp got fried,
Boy was I pissed and I checked the fuse which was burned and I opened the amp up and the heat sink smelled burnt and the caps right next to it ,
so my question is what could have fried and how much do you guys think it will cost?:eek:
It is an audiosource amp 100 bridged to 160 watts which really never even got warm for the past 2 years I have owned it and now poof.:(
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
Post edited by louthewiz on
Welcome!
    So many views and no feedback???:mad:
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    is the speak okay ?
    how old is the amp ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul!
    [PHP]is the speaker okay ?
    [/PHP]
    Yes it is
    [PHP]how old is the amp ?[/PHP]
    around 2 years old
    [PHP]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
    [/PHP]
    Well I guess I am one of the lucky ones to have a friend who repairs my stuff for me and is only charging me $50.00 to fix it.:D
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    Yes it is
    how old is the amp
    around 2 years old
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    Yes it is
    how old is the amp
    around 2 years old
    [/QUOTE]Perhaps it's because it was bridged. Most amps when bridged can not drive low impedence's (below 8 ohms). My guess is it finally gave up the ghost in a big way. Another possibility is just plain old component failure. But if I had to guess running the center in bridged mode might have been to much for the amp long term.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    Is it possible that the speaker cables were touching? (i.e. even a few of the positive strands were wandering over to visit with the negative terminal (or vice versa) That would create a 0 ohm load (or there abouts) and could easily fry a bridged amp.
    Other than that - just unlucky timing. (didn't spill anything into it did you??)
    Michael
    (anyway - sorry to hear about the amp, but glad to hear about the relatively inexpensive fix)
    I use heavy duty banana plugs and none of the strands were touching ,and as for spilling anything on the amp it was sitting on top of an A/V rack and I have no kids in my home.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    Sorry to hear what happened to your amp Lou.
    I would also guess that it happened because it was bridged. From what I hear it is not a very nice thing to do to an amp even though they say it can be done.
    I would take the opportunity to simply get a more powerful amp and wire it straight.
    Amp repair update,
    my buddy rplaced the outputs and the caps and after a while of testing it blew out again. (good thing there was no charge)
    I think I'm just going to just save my pennies and buy a used amp or try to find one on the bay since I still have $105.00 left over in my paypal account from a gift certificate.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
    was it two channel or a mono- if you want bang for the buck, cheap in price and quality try outlaw, adcom, something similar.
    If the speaker is OK, then it probably isn't the output transistors, but it is still a good place to work back from. I'd check em anyway if you smelled something on the heatsink.
    -Ignorance is strength -
Welcome!
Welcome!
