Help
PolkFan1
Is it necessary or even possible to hook up something like an Onkyo DX-C390 cd player to a HK 3480 stereo receiver using the optical or coaxial outputs the Onkyo cd player has? There is no optical or coaxial inputs inthe back of the HK however, just red and white
Post edited by PolkFan1 on
PolkFan1 wrote:Is it necessary or even possible to hook up something like an Onkyo DX-C390 cd player to a HK 3480 stereo receiver using the optical or coaxial outputs the Onkyo cd player has? There is no optical or coaxial inputs inthe back of the HK however, just red and white
if your receiver does not have an optical input... the answer is no. it can't be done going the optical route. you would have to use the red and white RCA plugsPolkFest 2012, who's going>?
Just RCA for you sir. No digital here.
Well, not unless you pick up a separate DAC. You'd stick the optical into a DAC, and the RCA into your onkyo.
Other than that, no luck for you.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
am i missing out on anything by just using the red and white connection rather than the digital ones? Its just an oknyo cd player and no dvd player in it.
Not really, your just using the Onkyo's internal DAC's. You might squeeze better sound out of it by going to an good external DAC, but since your running a receiver, i don't think it would be worth the dime(s). No offense, just understand that receivers are limited in their resolution, especially for the subtle changes an external DAC will provide versus it's cost.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Ok well then in that case I think the best thing I should do is just upgrade the red and white cables the cd player came with because I hear the factory cables are junk. Should that do anything? I can get Monster Ultra 600 THX RCA cables for extremely cheap. Like 25 bucks
PolkFan1 wrote:Ok well then in that case I think the best thing I should do is just upgrade the red and white cables the cd player came with because I hear the factory cables are junk. Should that do anything? I can get Monster Ultra 600 THX RCA cables for extremely cheap. Like 25 bucks
yeah just replace the cables that came with the CD player.. and you're set. enjoy.PolkFest 2012, who's going>?
