B&k St3140
Huck344
Huck344 Posts: 453
edited February 2007 in Electronics
Hello all!
There is a listing for the B&K ST3140 on ebay for a buy it now price of $399? Can anyone tell me if this is a good price. It puts out 140W per channel at 8 Ohms. I would run my two RTi8's along with a CSi5 center. Should I look for a 200W x 3 amp instead? One final question, how long ago did they make this amp?
Thanks,
Eric. . .
Post edited by Huck344 on
  • Ern Dog
    Ern Dog Posts: 2,237
    Eric,
    This model was produced between 2000-2002.
    The price seems fair. 140wpc will bring those Rti's to life. B&K is a warm sounding amp and is a great combo for Rti's, as they seemed a tad bright to me. I tried a B&K 150wpc and have a B&K 220wpc- the 220wpc seemed to produce a slightly fuller soundstage, just slightly. You'll be happy either way!
    Good luck.
  • Huck344
    Huck344 Posts: 453
    Thanks Ern Dog. To be completely honest, I like the brightness of the RTi's. I was really concerned that the 140W per channel wouldn't be enough. My current AVR is an Onkyo 804 which puts out 105W per channel. Though they sound good, I feel like they could sound even better.
  • Ern Dog
    A 140wpc High Current amp will sound a 100 times better than Onkyo's 105wpc. you have to remember that a lot of avr manufactuers have misleading wpc figures in order to increase sales. I bet you would be lucky to be getting 80wpc in stereo mode and even less with all channels being driven at the same time.
    Be prepared for a warmer, more refined flavor if you plan on getting a B&K amp. If you want to keep the bright/detailed sound, then I'd go with a more neutral sounding amp.
  • Huck344
    Huck344 Posts: 453
    Thanks for the advice! I'm going to meet with a friend tomorrow who has several different type of amps so that I can test the different sound qualities!
  • Ern Dog
    That would be perfect. If you can, take your Rti8's with you, so you can hear what it sounds like with your speakers. Might be too much of a hassle.
