Speaker Selector Jimmy RIg
riglehart
riglehart Posts: 276
edited February 2007 in 2 Channel Audio
Can I take an Adcom speaker selector that takes one set of inputs and splits them out to 3 and use it "backwards"? I want to take 2 sources and be able to switch them between one set of speakers? I attached a picture of a similar one.
If so, I would have to be careful not to engage both sources at the same time, of course.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • hoosier21
    hoosier21 Posts: 4,418
    do mean connect two amps to one set of speakers?
    I would not
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • gidrah
    gidrah Posts: 3,049
    NO! There are separate units that can do what you are asking.
    Make it Funky! :)
  • ohskigod
    ohskigod Posts: 6,505
    yeah dude, I agree with the rest. I wouldnt do it, it just aint worth the risk. you can mess things up at both ends that way I think
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ben62670
    ben62670 Posts: 15,969
    The Adcom GFS is an ohm compensating switch. I would NOT do it. And like you said an accidental switching on of both amps could be very very bad.
    If you are handy with general electronics you could try to find a 4 pole double throw high current switch. That way there is no chance of damaging your amps except for improper wiring. What kinda power are you trying to route, and why?
    Curious Ben
    Ben
  • TheReaper
    TheReaper Posts: 636
    I you like Dr Frankenstein, you could use 2 DPDT knife switches (1 on each speaker) :)
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • riglehart
    OK. You all have talked me out of it. I just want a way to do simple system A vs B comparison, with all else equal.
    I can building something like you suggest that isolates the systems from each other. I was hoping to get by easy.
    Jolida Tube
