Speaker Selector Jimmy RIg
riglehart
Can I take an Adcom speaker selector that takes one set of inputs and splits them out to 3 and use it "backwards"? I want to take 2 sources and be able to switch them between one set of speakers? I attached a picture of a similar one.
If so, I would have to be careful not to engage both sources at the same time, of course.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
do mean connect two amps to one set of speakers?
I would notDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
NO! There are separate units that can do what you are asking.Make it Funky!
yeah dude, I agree with the rest. I wouldnt do it, it just aint worth the risk. you can mess things up at both ends that way I thinkLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
The Adcom GFS is an ohm compensating switch. I would NOT do it. And like you said an accidental switching on of both amps could be very very bad.
If you are handy with general electronics you could try to find a 4 pole double throw high current switch. That way there is no chance of damaging your amps except for improper wiring. What kinda power are you trying to route, and why?
Curious BenPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I you like Dr Frankenstein, you could use 2 DPDT knife switches (1 on each speaker)Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
OK. You all have talked me out of it. I just want a way to do simple system A vs B comparison, with all else equal.
I can building something like you suggest that isolates the systems from each other. I was hoping to get by easy.Jolida Tube
