Echo Busters
jmasterj
jmasterj Posts: 327
Hey Out there in polk audio land are any of you using echo busters, or any other objects to tune your listening rooms? Know anyone that uses them? What do you think?:confused:
JmasterJ Polk to the Death
  • joe6pak
    joe6pak Posts: 267
    edited December 2002
    jmasterj
    Perhaps when mantis gets back, he will have some info about your question. I knew he would be missed.
    joe
    F1nut Posts: 51,695
    rlw uses them, he posted something about that somewhere in here.
  • rlw
    rlw Posts: 231
    I'm using ASC and EchoBusters in my current 2-channel setup. I haven't heard a room yet that wouldn't be improved by these products. Of course, I haven't heard every room, and yours could be different.
    If you read through some of my posts, I've described how I use them, and what changes with various configurations for me.
    If you have any specific questions, I'll be happy to try and help you out.
  • jmasterj
    jmasterj Posts: 327
    Thanks Guys,
    rlw, I was wondering if maybe a cheap substitute would/could serve the same purpose? Something like acoustical celing panels. Also I was wondering how you decided where to position the panels. Did you send EchoBusters your room set up, or just experiment with it yourself?
  • rlw
    rlw Posts: 231
    Originally posted by jmasterj
    Thanks Guys,
    Sorry it took me so long to get back to this. Work is just kicking my ****, and I haven't had any time to even kick back, let alone post.
    A cheap substitute might/might not work. Depends on the frequency range you're dealing with, and the magnitude of the problem.
    Check out this link: Jon Risch's Site
    Jon has decades of experience, and is currently a designer at Peavey. He has some decent ideas on homemade acoustic control devices.
    The first room I did - do a search on my posts, I've talked about ad nauseam before - I worked with ASC on quite a bit, but ended up with my own combination solution. I'd say that whoever will give you some ideas for free is a good source for learning right now.
    As far as where to position stuff: reflection points come first. You have first reflection points on walls, ceilings, and floor. To find them, sit in your listening position. Have a friend take a hand mirror, hold it flat against the right hand side wall, and walk up and down the wall. When you see the tweeter from the right-hand speaker in the mirror, you've found the first reflection point on the right wall.
    The second reflection points probably matter less: same idea as above, but while doing the right wall, look for the *left* speaker's tweeter.
    Other areas: behind the speakers is usually a good place to start, as well as behind the listening position. You might want to use Auralex foam for this - you can buy a couple of panels at your local musician's store, or online for a few bucks - and move it from location to location in your room and listen to what happens.
    As far as commercial products go: I really like the Acoustic Science Corporation [ASC] products, use them a lot, and can't imagine putting a serious system together without them. Check them out at:
    ASC
    I do have EchoBuster corner points in one listening room, and they work.
    Let me know if you have any specific questions, I'll be happy to try to talk about it as I am able.
  • Jstas
    Jstas Posts: 14,977
    I followed the links, read teh sites but I'm not clear on what an Echo Buster is? Can some enlighten me please?
    Expert Moron Extraordinaire
  • jmasterj
    jmasterj Posts: 327
    edited January 2003
  • Jstas
    Jstas Posts: 14,977
    edited January 2003
    Cool! Thanks! They look like a neat idea. Especially for people who have large flat, unbroken spaces in thier viewing and listening rooms. Doesn't break-up a decor too much but offers alot of functionality.
