Carver Haters Beware
candyliquor35m
candyliquor35m Posts: 2,267
edited February 2007 in 2 Channel Audio
I know everyone loves their system well I hope so but maybe we don't talk enough about them. My hat goes off to Bob Carver. I firmly believe he frets over every little musical detail in his products. What I'm impressed with is their ability to sound somewhat tubelike and I've read that he's a huge tube fan so I think he went/goes the extra mile because of that love. He doesn't just use any transistor. I think he listens to all of them and picks the one he likes the best. Better systems? Of course but I'll be older and grayer before I buy them. Solid core interconnects and speaker wire throughout, SDA 2b's, TFM-45, CT-24 pre, cheap old sony cdp. Can't wait till will can listen to each others systems via a line out to our pc then internet it around the world to waiting pc headphones without losing too much hi-def. Maybe that's already possible.
Post edited by candyliquor35m on
  • Polkersince85
    Polkersince85 Posts: 2,883
    Somebody forgot to take their medications.:D
    P.S. I like Carver, too.
  • TroyD
    TroyD Posts: 13,124
    The preamp wasn't, I'm fairly sure, a Bob Carver design.
    Nice amp, though.
    BDT
  • dorokusai
    dorokusai Posts: 25,576
    I'm not a Carver fan.....However, I respect the design and Bob, as he was a pioneer in the FU establishment type HI-FI arena.
    It's attitude that creates new things in audio, as everything else is rudimentary.
  • candyliquor35m
    Nice amp, though.
    BDT
    You're probably right. The pre- was made in china and has a major flaw imo. The outer part of the rca jacks (I don't know if that's called the ground or what) are just pressed in by hand and come out easily if I have a rca plug that fits tight. Not a deal breaker because I just push them back in but an inconvenience to say the least. The pre seems to have a good sound to it, clean, clear and detailed. The am/fm switch stopped working and I had to take the faceplate off and clean it. seems to be fine now. I've been tempted to upgrade but it has both a onboard tuner and phono input. I appologize for any audio lingo I've screwed up :o
    Actually that's the easy part. A daily injection of copaxone which from what I've researched is only 2 amino acids but it seems to have helped over the years. A lot of the other approved medications are in the interferon family if I remember right and have more side effects but I haven't tried any of them.
  • AndyGwis
    AndyGwis Posts: 3,655
    I'm running a Carver M1.0t and C-2 setup right now. Sounds good, but I'm not sure how it stacks up to my B&K gear. Gonna spend some time with it listening to some familiar tunes to solidify my opinions on the two systems.
    Carver is great gear for the prices, tho. Amp for $250 - $300, preamp for $150 and you've got a decent system with plenty of power.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Refefer
    Refefer Posts: 1,280
    One nice things about carver is that their Watts per Dollar is perty darn small... which makes it ideal for those low sensitivity systems, and gives you plenty of headroom... on the cheap!
    I seriously considered the TFM-35 when I was looking to upgrade my amp for SDA's.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • halo
    halo Posts: 5,616
    I take the same stuff. Tried Avonex but that's a big effin needle and the side effects sucked. When/how long ago were you diagnosed? For me it was '85 and I was 11 years old :eek:
  • candyliquor35m
    damn 11 years old. normally it happens in our 30's which if my math is right, I was 38 in 1998 so next year will be my 10th anniversary in which according to what I've read, 50% are in wheelchairs by their 10th anniversary. I'm stubborn tho, I took tons of iv corti-steroids (solu-medrol) to keep me walking and now, knock on wood, I'm in a long remission stage and haven't used the solu-medrol in over a year. I think giving up alcohol helped and also getting plenty of rest and as little stress as possible.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    Good to see other carver fans coming out of the closet.
  • Ron Temple
    Ron Temple Posts: 3,212
    I haven't heard many amps (3), but I did listen to my 1Cs on an integrated Marantz RM7200 in Class A and Class A/B (it's switchable), it was very detailed, but too bright and grainy in the highs. The TFM 35 seems to be a match made in heaven for my tastes. Everything sounds smooth as silk, tons of headroom and dynamics. For the price, I'm not apt to experiment for awhile.
    BTW the price on these amps on ebay seems to be going through a spike. If you want to move your gear, you might get 35-40% more than last year.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bikerboy
    bikerboy Posts: 1,230
    Hi Candyliquer,
    I used "The Cube" back in the day. A piece of **** but my brother still has his M-500 amp and TX-11? tuner. I used a carver reciever as an amp for a while in the mancave. Made a ring in the upper freq that I couldnt get to go away. But the tuner in the CT-17 I use works well and sounds great. Sometimes when listening to the radio I forget it is FM not a cd. Great imaging with the sda2s. If you really like it those rca jacks can be replaced.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • candyliquor35m
    bikerboy wrote:
    Hi Candyliquer,
    Hey thanks. I never thought of replacing the jacks but that's a great idea. Definitely on my to do list. Don't ever change your last name ;)
  • AndyGwis
    Great idea!
    Can someone explain the easiest way to replace RCA jacks? I would do that as an upgrade project for my Pro-10MC, would give me a reason to keep it if the upgrade isn't too expensive or tedious.
    The RCAs on my Pro-10MC are connected by a ribbon internally and externally look to just be held on by two small solder points. I'll try to post a pick, they are the old school style for the Pro-10MC.
  • AndyGwis
    Here's a pic. Let me know if I should just take this hijacking to a new thread in DIY section.
  • candyliquor35m
    It's all good info. Once I post a thread, it belongs to the forum to use, abuse, hijack, etc as you see fit.
  • ohskigod
    ohskigod Posts: 6,505
    love my 4.0t, cant say it enough. same amp inside as the tfm45 you got, just different case and look. oodles of power, and i have no inkling to upgrade
    I did recently win an auction for a Hafler 500, and since I allready own one, looks like I'm going to see if Hafler 500's biamped will beat out the Carver on my AR9's.
    worse case, the Carver goes back to my theater system, it sure as **** aint being sold anytime soon (even though they are fetching plenty of cheddar on the used market)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Ron Temple
    You got that right...I should have jumped on the 4.0t for $500 in Dec...they are going from $650-800 now.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • snow
    snow Posts: 4,358
    Yes amazing isnt it, the price jump in carver amps lately. I was thinking it was only because of tax checks coming up loans. But i dont think so now. I have a TFM-35X running my sda srs 1.2 tls now and it seems to do a fine job. Not to steer people off the subject here, but has anyone owned a proton AA-2120 amp and if so how would it do compared to the carver i have now? THANKS SNOW
  • Lsi9
    Lsi9 Posts: 616
    If you like carver gets yourself a Sunfire, yes it does have that tube quality to it for a SS amp, Only way Im replacing my sunfire is if I go all tubes one day, love it.
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
