Porch Ceiling progress...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited February 2007
    hoosier21 wrote:
    outdoors type and screw Behr overpriced Home Depot crap
    Screw Behr overpriced crap? I not sure about their stains, but the indoor paint is the best. IMO
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • hoosier21
    hoosier21 Posts: 4,420
    I was basing my opinion on the indoor paint, they stuff was not our favorite when we repainted the whole house, didn't spread well or cover well. Hey I am no expert, just full of opinions.
    I guess you will have to stain then seal, what a ****, I HATE overhead work.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • disneyjoe7
    schwarcw wrote:
    Looking good Steve! You can use any stain if you are going to put some poly on over top. I would recommend the poly coat with the humidity in your area.
    The Payphone is a real cool factor! Hang it up and leave it for a couple of days before doing the permanent fastening. It is bigger than you think and it might be an obstacle to foot traffic. Just my $0.02. Good luck!
    Thanks for the kind words. I don't think the payphone will be in a bad area, I should have it up this weekend. I post a picture when done, it's more of a weight issue then anything the thing must weigh 30lbs or so. I was going to mount with 160lb toggle bolts 1/4" X 3" since this is a stucco wall, I dilled the six holes needed 3/4" hole in stucco. Drilled 6 in the wall 3 in the wall, 3 others over a 2x4 on the right side. So I need to get some lag bolts for this side first. You start something like this and it's a lot of back to the store for something trips. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Look from pool area.
    Look from bedroom.
    Pay phone has been mounted ;)
    Work on porch has been slow mainly because this one project has turn into 5 all the wiring for HT or House audio, my IP closet the AV closet.... I left this open for a better access into attic, since it's a nice time of year not being too hot.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • [Deleted User]
    [Deleted User] Posts: 763
    Yeah, it's not too hot here either. Boo-hoo!!
  • disneyjoe7
    Attic work SUCKS I say but it's better when the attic is 85f vs. 145+f.
    For you Josh I hope for 68f with a nice southernly breeze.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
