Can't get Power Amplifier to work...
Dot40
Hey guys,
I just got an Aragon 2005 amplifier and am trying to get it to work with my system. Here are my connections: I have an Oppo DVD player which is connected to my receiver (Denon 2807) using a DVI-HDMI cable. I'm running an optical audio cable from the dvd player to the receiver. I connected the power amplifier to the receiver using Monster RCAs and then obviously connected the speakers to the amp with monster speaker cable. There was no difference in sound volume when i started watching a dvd, and then tried turning the amplifier off..... Sound still came out of the speakers at the same volume as when it was on... I called Denon's tech support and they said i needed to run a pair of red/white audio cables from the dvd player to the receiver. Well I did that and there was no difference. Any ideas on what I'm not doing??
Post edited by Dot40 on
is your Aragon amp hook up to the pre out puts on your Denon? sounds like you have it hooked up right. but I have no idea why when the amp is turned off.. you are still getting sound from your speakers.. so something is actually wrong with your hook up.
You should not need to run a pair of red/white audio cables from your dvd to your receiver.. you already are using the optical cable for audio.
sorry i can't be of any more help. this is very odd.PolkFest 2012, who's going>?
Sounds like you have it connected to the wrong pre-outs.
Not familiar with your avr but look on the back,might say
audio out or zone one audio out.make sure your interconnects
from your amp are going to the left and right audio out in this section.HT SYSTEM-
lsi 9's -
The amplifier needs to be connected with audio cables from the pre outs to the amps inputs with 5 rca cables and all the speakers get connected to the amp,
as for the amplifier if it has a gain or volume dial in the back or the front make sure it is turned all the way up and then run the auto setup to compensate for the new amp to make a difference since the avr is now being used as a processor.
And finally you will need an spl meter to properly setup the levels and sub woofer and the dvd player is already feeding the amp with the optical cable,
Here are some links to help you get the spl meter and how to use it etc.
http://www.bswusa.com/proditem.asp?item=SLM100
http://www.audiophilia.com/hardware/spl.htm
http://www.techlore.com/article/10037/;jsessionid=1EB44AF24FE014D8DE008AB481B8A36FMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
I have it connecting to the "preouts" section in the back of the receiver. When i spoke to Denon they said I need a seperate Preamp, and that I would connect everything to the Preamp, and then to the Power Amplifier.... is that true??
Doesn't sound right... -
Make sure the IC's from the amp are connected to the PREOUTS on the Denon which are directly below the EXT IN connections which is where the IC's from the DVD player would go.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
NO that is what the preouts are there for!Dot40 wrote:I have it connecting to the "preouts" section in the back of the receiver. When i spoke to Denon they said I need a seperate Preamp, and that I would connect everything to the Preamp, and then to the Power Amplifier.... is that true??
Doesn't sound right...Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The Monster RCAs are plugged in the Preout section on the receiver and they are going to the Aragon amplifier. I did the auto test again.
Also i noticed the receiver has a Power Amplifier setting, but it only gives u the options of fronts, surrounds, or zode 2... -
The amp sections in the Denon "do not" need to be used all the work will be done with amp and the avr will "process" the sound.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
obviously what it sounds like to me is that your amp continues to provide power for a little while after you shut it off. some amps shut down slowly rather than all at once. after you shut the amp off it may continue to have enough power to make noise for a little while. if it doesnt stop after 2-5 mins then you have other issues. wait for a little bit after you shut it off to see if it stops on its own, before you panic. REGARDS SNOWDot40 wrote:Hey guys,
I just got an Aragon 2005 amplifier and am trying to get it to work with my system. Here are my connections: I have an Oppo DVD player which is connected to my receiver (Denon 2807) using a DVI-HDMI cable. I'm running an optical audio cable from the dvd player to the receiver. I connected the power amplifier to the receiver using Monster RCAs and then obviously connected the speakers to the amp with monster speaker cable. There was no difference in sound volume when i started watching a dvd, and then tried turning the amplifier off..... Sound still came out of the speakers at the same volume as when it was on... I called Denon's tech support and they said i needed to run a pair of red/white audio cables from the dvd player to the receiver. Well I did that and there was no difference. Any ideas on what I'm not doing??Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
snap some pics of the connections on all components so we can see it. cant hurt
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Snow was right. I waited a couple minutes after shutting off the amp and the sound faded away. Sorry for the stupid error....
My only question remaining is: Do amps increase how loud your speakers go? Or is it more of the quality of sound? -
Dot40 wrote:Snow was right. I waited a couple minutes after shutting off the amp and the sound faded away. Sorry for the stupid error....
external amps..provide cleaner power to your speakers.. usually they provide better sound quality over loudness.. but your speakers will perform better with an external amp.PolkFest 2012, who's going>?
yes agreed. also you will probally notice a big difference in bass with an outboard amp if it has enough power. I dont think your speakers are going to sound louder but you will be able to depending on your drivers be able to play at louder levels safely than you can with a smaller amp. tweeters are more prone to damage due to distortion than anything. so if you are able to push your speakers to whatever limit they can handle with a bigger amp without distortion then you are winning. if for some reason it isnt loud enough by then, go find new speakers that are more efficent. the aragon you have is a nice amp and should handle most peoples needs fine though. HAPPY LISTENING. SNOWdanger boy wrote:external amps..provide cleaner power to your speakers.. usually they provide better sound quality over loudness.. but your speakers will perform better with an external amp.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
