Denon DP-300F turntable any good?
marker
Post edited by marker on
I like what they have come up with for their middle table. Belt drive, and fully automatic operation are nice. It looks like it is aimed at the Music Hall/Rega entry models.
The downside of the Denon table lineup has always been the proprietary arms being tough to impossible to replace/upgrade.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks for the response Dennis. That was exactly what caught my eye about it, not to mention the built in phone stage.
Anybody else have any experience at all with this model? -
Only weighs 12lbs. I doubt it is a very solid table. Even the lowest Music Hall weighs 17lbs. Some may argue, but I believe you can judge a table by its weight and tell a lot about the quality of construction. I personally wouldn't touch a table that weighed less than 20lbs. The VPI I have coming weighs 49lbs.
For the money, you could get a Denon from the 1980's that would kill this model (DP-62, et al). Still, for a current production, all-in-one solution, you could probably do much worse.
Sounds like a Scoutmaster.:cool:billbillw wrote:The VPI I have coming weighs 49lbs.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote:Sounds like a Scoutmaster.:cool:
Nope, old HW-19 -
billbillw wrote:Only weighs 12lbs. I doubt it is a very solid table. Even the lowest Music Hall weighs 17lbs. Some may argue, but I believe you can judge a table by its weight and tell a lot about the quality of construction. I personally wouldn't touch a table that weighed less than 20lbs. The VPI I have coming weighs 49lbs.
Actually the Music Hall is 17lbs including packaging. Without packaging they are probably really close. However I would bet that the Music Hall is a better performer.
There are a few other table in that price range that I would consider before this one.
However I really have to give Denon credit for having 3 turntables on the market.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
