Denon DP-300F turntable any good?
marker
marker Posts: 1,084
edited February 2007 in 2 Channel Audio
Post edited by marker on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I like what they have come up with for their middle table. Belt drive, and fully automatic operation are nice. It looks like it is aimed at the Music Hall/Rega entry models.
    The downside of the Denon table lineup has always been the proprietary arms being tough to impossible to replace/upgrade.
  • marker
    marker Posts: 1,084
    Thanks for the response Dennis. That was exactly what caught my eye about it, not to mention the built in phone stage.
    Anybody else have any experience at all with this model?
    billbillw Posts: 7,800
    Only weighs 12lbs. I doubt it is a very solid table. Even the lowest Music Hall weighs 17lbs. Some may argue, but I believe you can judge a table by its weight and tell a lot about the quality of construction. I personally wouldn't touch a table that weighed less than 20lbs. The VPI I have coming weighs 49lbs.
  • Toka78
    Toka78 Posts: 192
    For the money, you could get a Denon from the 1980's that would kill this model (DP-62, et al). Still, for a current production, all-in-one solution, you could probably do much worse.
    SCompRacer Posts: 9,122
    Sounds like a Scoutmaster.:cool:
    Nope, old HW-19
  • cmy330go
    cmy330go Posts: 2,341
    Actually the Music Hall is 17lbs including packaging. Without packaging they are probably really close. However I would bet that the Music Hall is a better performer.
    There are a few other table in that price range that I would consider before this one.
    However I really have to give Denon credit for having 3 turntables on the market.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
